Hardware source for automotive bolts, washers?
I haven't had much luck finding a source for replacement washers and bolts for my engine rebuild. Secondly, the original porsche hardware seems to be on backorder very often. Specifically, I am looking for (according to PET) m12 x 1.5 washers for the head studs. Any leads?:jumper:
Here are some 12 x 2.5...
http://www.eagleday.com/washerkits.html They seem to stock lots of metric stuff, and the price is right. http://www.eagleday.com/fayzi.html |
Maryland Metrics stocks any metric fasteners or any metric hardware known to the civilized world. Ask for John.http://mdmetric.com/
Hammer |
Wurth also has it, it is all I use for nuts, bolts, clamps etc.
Originally Posted by Orest
(Post 6583712)
I use bolt depot for lots of stuff. |
I'd be careful about sourcing these outside of Porsche. They're probably grade "12.5" and may be extra thick.
I have purchased from boltdepot.com
Fastenal (sp) is a source too. Their website says they have a washer similar to the rubber backed one used on the valve covers on an '85. |
Originally Posted by GlenL
(Post 6584573)
I'm reasonably sure that washers aren't spec'd by the same grading as bolts. But they will be hardened for sure are probably thicker than, and probably won't have chamfered edges like, a plain washer. They may possibly have a surface finish that is higher quality than a plain stamped washer, reduce torque losses when tightening. Not a home despot purchase. |
you should either use the old washers of the correct type or new ones of the correct type.
They dont usually go bad unless they have gotten corroded, i am sure there are a few used ones floating around that will work fine |
Originally Posted by 6.0-928S
(Post 6583821)
Hammer |
Fastenal?
Thanks Dan Perez for hooking a fellow Rennlister up with some washers!
Originally Posted by cold_beer839
(Post 6587629)
Fastenal?
