Piston wrist pin offset
What do you disagree with? Yes, by all means, use the arrows, it makes sure the offset is correct. If you have Asymetrical pistons like the S3 and it seems the 968 from what was said, then one side will be optimal and the other will be wrong. With the 2 valve conversion, we can correct this by spinning one side of the pistons around to be correct for the offset. IN otherwords, if the arrows point to the front of the engine, you are taken care of. if it points to the exhaust side, you have engine side wrong, unless there is no offset in the piston set up. But in that case, there is nothing you can do about it, except cut new valve reliefs. (and maybe do the other side too to keep the compression ratios identical )
The S4 has symetrical pistons, so there is no difference in the valve pocket depth, and the front engine pointing arrow that forces the pistons to spun around opposite on each side. Again, with the S3 and the 2 valve conversion, why wouldnt you take advantage of the chance to make it right?
Now, which way you orient the pistons, that was advised by Greg and I forgot which way is optimal. sounds like the greater angle on the powerstroke gives better power, which would put the wide side toward the exhaust on the driver side as looking at the front of the engine.
mk
mk
This topic Mark I disagree. Follow the manual. Arrows point to the front. Small valve pockets point towards the exhaust manifolds.
Erkka, When I assembled my 5.0L I had the pistons ceramic coated. The coating covered the arrows. Luckily I had 9th junk piston to follow. Small exhaust pocket toward the exhaust manifold.
Tony
Tony
So I guess my initial post was right then recapping what Greg had mentioned. So, if the narrow side faces the exhaust side on the 5-8 cylinders, this means there is a straighter angle of the rod and piston. does this induce more power but a chance for piston slap? I dont know, but Scots was built this way, and all the 2 valvers have one piston bank "wrong" and Ive never heard piston slap in any of them. So, the drawing is opposite is how they should be installed. BUT, I seemed to remember that one of the sides was correct on the Scots. So, did we do it backward? Now I'm confused. Here is a picture of what we did. Driver side (as shown) was installed in the way it would normally be in the S3 engine. Passenger side was done the opposite to match the offset. From Greg, " Install the piston so that the rod angle is straightest acting on the crank for most power". This would mean the 5-8 pistons are correct with the narrow side toward the exhaust side, and the driver side pistons need to be spun around.
Greg????
Greg????
Basic Site Sponsor
Basic Site Sponsor
Like I said...too much brain damage.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
If this really is an important issue, why not design the block in a way that the crankshaft is offset and producing a shallow rod angle during the power stroke? A V engine would look a little like left-tilted L engine, where the left bank is taller and the crankshaft is offset to left? Assuming the crankshaft rotates clockwise.
Basic Site Sponsor
Basic Site Sponsor
I am talking about having the crankshaft main bearings moved to the left. This is an extreme version drawn just to illustrate the point:
Basic Site Sponsor
Basic Site Sponsor
Tony,
On S4 etc. '87+ pistons have same four size valve pockets. As there is only one piston style all four pockets must be same or offset would be wrong way round on one side of the engine.
Just checked one S4 piston which arrow is visible. Based on it this is correct setup. Looking from the front of the engine.
Basic Site Sponsor
Basic Site Sponsor
My understanding of this offset business is limited to what I've read on the internet. Caveat emptor.
I am planning to install the pistons with the shorter side to the direction of rotation. I am believer in keeping the rod angle shallow on the power stroke. That and $1.89 will get you a venti cup of coffee at starbux.
I think (but do not know) that reversing the pistons will alter a couple of things:
If the crankshaft is not offset, then zero-offset piston pin will bring the piston as high as possible. Any offset will lower the max travel height of the piston, no matter which way. Because of symmetry, the max height doesn't change when reversing the piston with zero crank offset.
If the crankshaft is offset, however, the piston pin offset of same magnitude in the same direction will bring the piston as high as possible. Thus, if the crankshaft is offset, the deck height, compression ratio, etc. will change when piston is reversed. Many things are affected.
Can someone confirm that 928's 90-degree V8 has zero crank offset? [Edit: I think it has to be, since the intake ports are level between banks and the bare left and right heads are interchangeable.]
Even if the crankshaft is not offset, reversing pistons will alter timing because it alters the rod angles. Suppose the engine rotates clockwise. If the short side is on the left, the piston will come up to TDC earlier in the crank angles. If the short side is on the right, the piston will come up to TDC later in the crank angles. If the cam timing is not adjusted, in principle the valves could hit the pistons when pistons are reversed even on zero crank offset engine. It seems to me, and don't believe this without thinking it thru yourself, that if one reverses the pistons from having the short side on the left to having the short side on the right, then one should also retard the camshaft timing.
Does this even make any sense?
If the above about cam timing makes sense, it would be interesting to figure out whether the relative cam timing of the left and right banks was adjusted when Porsche decided to stop installing the pistons in the different offset directions and to start installing them in the same offset directions between banks.
Here's an interesting calculator:
http://www.wfu.edu/~rollins/piston/offset/offset.xls
Some simulation results that seem to say that there's a tradeoff:
http://202.117.208.15/CMDNETUpload/book/33.pdf
Reversing pistons:
http://books.google.com/books?id=sZH...esult&resnum=1
Reversing pistons:
""Porsche screwed this up for so many years and on so many cars...it's just stupid."""
Without a doubt, this is the most real comment I have ever read on Rennlist!!!
And they still screw it up. On all 911 pistons, a set will give you 1/2 right and the other 1/2 wrong.
