Rob's GTS engine pull
#61
Basic Site Sponsor
Basic Site Sponsor
That would be a stroked and bored elephant?
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
#62
#65
Not the sharpest tool in the shed
That's gonna be one FAST elephant when they're done with it...
#66
#68
Supercharged
I was going to post my hypothesis, but after typing it out, I realized I don't know enough about this stuff and would be merely conjecture. It's fascitaing, however, that the nuts came off.
Good luck with the new motor or the elephant.
#71
Archive Gatekeeper
On topic:
Once the kiddos are asleep tonight the GT motor is coming off the engine stand and the GTS motor is going on, then it's coming apart. More carnage to follow.
For some reason my wife wanted a copy of the Pchopped elephant. Somehow I don't think that's going to end well.
#72
How do you get your kids to go to sleep? I try the same and end up wrenching in the wee hours.
I don't think anything good could come from that elephant photo.
#73
Archive Gatekeeper
Well, I took the motor completely apart today (except for piston #2) and the news is mostly bad. As you will see, the crank is toast (unless there's a way to weld up a whole lotta material onto rod journal #2.
I will let the pictures do most of the talking:
Before teardown:
Heads off- note valve damage on top of #2- It bent the valves in cylinder #2
Nice wear on the thrust bearing:
My guess is the block is done too, #2 looks pretty bad (and I can't yet see what's under piston #2, which is still stuck in the bore.:
Cylinder #2 from above:
Cylinder #2 from below (May not be suitable for minors......)
Cylinder 6 from below- note the one ding in the wall- definitely big enough to catch a fingernail on it......
Pistons: #1 is at bottom right, #5 is at top right. Something smashed into #5 and cracked it pretty good:
The crank is oh so done- look at the lip between 2 and 6:
Note the bad heat discoloration on all of the crank rod journals (arrows, incase it's not completely obvious.....):
If anyone wants additional shots of things, let me know and I can oblige. Any and all opinions on how bad this is are welcome.
To make up for the carnage, I also managed to complete the cleanup of the GT motor, which is ready to go back in the car:
Before teardown:
#74
Thats quite a mess Interesting to see in the pic of No. 2 Cylinder chamber, it appears as if that cylinder was possibly burning oil for some time. It may be just how the photo is taken but definately looks darker in colour compared to the other two chambers.
Was it possible it was having a problem before the break up I wonder?
On the flip side that GT engine looks fantastic, nice work on that
Glenn
'81 928
Australia
Glenn
'81 928
Australia
#75
Craic Head
Wow. Now THAT'S carnage. I feel a little queasy looking at that, but your pics of the new GT engine are great. Looks really nice.
Good luck and thanks for posting all the photos.
