The Official 928 Bearing Failure Thread
Man of many SIGs
Hi everyone. With all the recent discussion about bearing failures in the 928 engines here on Rennlist. I thought it might be a good idea to compile all of the info in one place and try to make some sense of it all. If you have had direct experience with a bearing failure in a 928 engine, please provide as much info as possible. Information such as:
Which bearings failed:
What other parts were damaged:
Year of engine:
Mileage on engine:
Did the engine see track use:
Was the engine boosted:
Was the oiling system stock or modified. If modified, please explain:
What type and weight of oil were you using when the failure occured:
Any additional info that others may find helpful:
Thanks for participating. I know this is a morbid subject for some but information is power.
Year of engine:
Mileage on engine:
