928 Forum 1978-1995
Sponsored by: 928 Specialists
85 & 86 TPS Short Harness for Sale
Old 02-16-2009, 09:56 PM
ROG100
Basic Sponsor
ROG100's Avatar
Default 85 & 86 TPS Short Harness for Sale
Most of you that own 85 & 86 US cars know that the short harness that connects the TPS (throttle position sensor) to the engine harness is NLA (no longer available).
In most cases the connectors are literally toast and it is a PITA to replace the end connectors on an already deteriorated cable.
928sRus with the help of John Speake has a complete replacement short harness for $59.95 plus shipping.
Old 02-16-2009, 10:10 PM
Mike Frye
Craic Head
Mike Frye's Avatar
Roger,
I forgot to tell you, the one you sent me worked perfectly. I had previously made my own using the existing wire and new plugs, but the hardened plastic insulation was so brittle that I could barely bend it and I'm sure the wire was breaking inside it.
I highly recommend this for anyone doing the top end refresh. Thanks Roger!
Old 02-17-2009, 03:20 AM
Landseer
Landseer's Avatar
This wire carries the signal from the throttle position switch, access to which is pretty well buried by the intake pipes.
According to the 85 service publication, it has a plug end mounted near the front of the engine so that it can be unplugged to check the function of the sensor. (Otherwise, it could have been incorporated directly into the harness).
They fail when the end crumbles. Had to tape-up mine.
I made one for the 86, using Bosch ends and boots supplied by Roger. A piece of rubber vac hose carried the three wires. Worked well, but it took time to solder the connections and measure the wires and the insulation at just the right offsets. Plus, the cost added-up to nearly $40 for the pieces.
Roger just sent me one of the new cables. It will be used on the platinum 85. Thanks for reproducing this discontinued part.
Old 02-17-2009, 08:25 AM
SeanR
SeanR's Avatar
I am very glad that John and Roger took the time to get these to market.
Old 02-17-2009, 09:32 AM
Glen McCartney
Glen McCartney's Avatar
Roger, PM sent
Glen
Old 02-17-2009, 12:59 PM
Dannyfumi
Dannyfumi's Avatar
Roger,
Ill take 1 please, Ill pick next time I drop by.
Danny
Old 02-17-2009, 01:05 PM
Mark Anderson
The Parts Whisperer
Mark Anderson's Avatar
Good job guys
Old 02-17-2009, 01:46 PM
Mako 928
Mako 928's Avatar
Great job Roger/John this is a much needed (NLA) part that keeps restoring the 928 strong!! This also takes the guess work out of getting the wires in the wrong position when replacing the plug. That alone is worth the price which is VERY reasonable.
Old 04-02-2009, 01:53 AM
BIMMERMIKE
BIMMERMIKE's Avatar
Default How to postion new TPS?
I received and installed new TPS(Thanks Roger) now I'm not sure how to positon TPS for correct operation.
How do I know if in the right position?
Old 04-02-2009, 08:13 AM
Landseer
Landseer's Avatar
Excellent. Perfect fit.
Thanks, Roger.
Old 05-11-2019, 10:58 PM
JayPoorJay
JayPoorJay's Avatar
Calling up this thread in urgent need of advice. And yes, if they are still available I'll be needing one of these.
Does anyone know the orientation of the wire colors so I can limp home?
See link:
https://rennlist.com/forums/928-foru...l#post15834488
Quick Reply: 85 & 86 TPS Short Harness for Sale
