928 Forum 1978-1995
Sponsored by: 928 Specialists
36 Pound Injectors
Old 03-10-2009, 12:07 AM
Glenn M
Glenn M's Avatar
My mistake, I used a BSFC of 0.55 and a PSI 36.
I'm going to install a TS SC, I'm assuming 0.55 BSFC.
If I recalc 500 hp. 0.55 BSFC and 55 PSI 80% duty cycle I get 38.21 PSI.
550 hp get 42.03 PSI. This is what Andrew saw.
Glenn
AO
Supercharged
AO's Avatar
I've heard turbo's don't have the problem...
Old 03-10-2009, 12:22 AM
Kevin Michael
Rocket Pilot
Kevin Michael's Avatar
11.4 afr at wot is damn near perfect and and has a good margin of safety on boosted 928 cars. 11.8's would be perfect IMO. I'm running 42lb inj. and that's where I need to be.
Old 03-10-2009, 12:27 AM
PorKen
Inventor
PorKen's Avatar
Sterling - stock LH2.3 = 3.8bar/55psi (LH2.2 = 2.5bar/36psi)
CHP = 725
#Inj = 8
BSFC = 0.45
Duty = 0.80
PSI = 55
45.34# @ rated
IIRC, injector flow rates are rated at 3bar/43.5psi, shorted open, but when controlled by an ECU, they never reach this rating.
Quick Reply: 36 Pound Injectors
