Stroker ITB using M5 intake horns
#31
The runners look money.
Apropos nothing: The 4-valve modular Ford engine is a 928 knock off with some improvements. This is good news for us 928 owners for two reasons: First, as imitation is the sincerest form of flattery, this provides a helpful collective ego boost. Second, in case someone is working on a sheet-metal intake, all the intake manifold R&D that has been done on the 4-v Fords should pretty much "bolt on" to 928. For example, see:
http://www.musclemustangfastfords.co...est/index.html
http://www.amazon.com/Building-5-4l-.../dp/1932494200
#33
I can get six on and the last two won't quite go and sit entirely in their adapter rings. The air horns are two piece and are bonded together. We've already split one to allow the bell to be rotated in relation to the base. The horns will fit with no issue at all if the horns are oriented to make an "S" curve, but I'm assuming this bad for flow since there will be no long or short side along the enitre length of the horn. Any input on this?
(Edit: For an idea of what I'm referring to, see how the front horn sweeps back horizontally. Imagine rotating the bell 90 degrees counterclockwise so that it
I have no idea what angle would best, which probably doesn't come as a shock to many! ;-) . However, if I'd have to guess I'd guess the cork screw angle that makes the air screw in in a helical pattern would be the best flowing. If you measure the flow, I'd love to learn whether it makes a difference.
#34
It's close, so far so good.
I won't know for sure until I get the air box constructed. The tray will sandwich between the ITB and adapter, so that will raise the horns slightly. Then I have accomodate the thickness of the lid, and then allow enough wiggle room for the engine to cavitate without forcing the airbox into the underside of the hood.
The airbox will feed from the front like Louie and Hammer.
#35
Hey Tuomo,
Probably not going to invest in the flow bench work, at some point I thnk I just gotta run it and see what happens. It would be interesting to see what would happen with the flow, if anyone is real curious and has access to a flow bench, I could send one of the horns out for testing.
#36
Actually in thinking it about it, I could probably just rotate the inboard horns (#3 and #6) and that would create enough clearance for the other 6 to stay as they are. We'll see. Still curious if anyone has any input on whether having the horn rotated so the bell faces upward is a big no-no.
#39
My intake feeds from the rear, near the base of the windshield. The scoop faces the rear..........
Hammer
#41
Thanks Adam. A friend of mine in the Hemi club made it to my specs. He makes fenders, hoods, etc. from scratch for the old factory Hemi Super Stockers. I had some Hemi parts he wanted so we made a deal. He made the scoop & I made the opening, the screen, & retaining plate using titanium bolts. (gotta keep the weight down) It'll stick through a hole in the hood & be a shaker scoop. The scoop IS my airbox.
Hammer
Hammer
#43
Just imagine it facing forward & then just turn around!
I'm not hijacking Adam's thread. I'll start a seperate thread soon & show it in progression.
Regards, Hammer
Regards, Hammer
