WARNING: Rayco Eurospec Motorcars - Kingston, Pennsylvania
#35
On a 5-speed if you are just swapping it out, it is quite easy. If you have the right length extension, you don't even need to remove the clutch. But in an auto where you have to remove the transmission and rear suspension, 10 hours and $800 doesn't sound bad.
Dan
'91 928GT S/C 475hp/460lb.ft
Dan
#36
Hmm, so I found a thread on the list that seems to indicate you can actually slide the trans back far enough to get the entire thing out without removing the trans or rear suspension. Stop scaring me guys Conflicting information is confusing
#37
Dan
#38
Supercharged
You have to loosen the trans and maybe suspend it in order to get enough play, but the trans does not have to coume out. Rear suspension should be able to stay in place. I would think you could have the TT out in about 2 or 3 hours with a friend helping while working on your back.
#39
I drop the crossmember, then remove TT and trans as a unit. And replace the same way. Am slow and methodical on separation step, also on refitting. I use a rolling shop stool with adjustable height to support the front of the TT.
Its a whole lot easier to remove & retorque the 4 bell housing / TT bolts than to remove / refit the 6 that connect the TT to the TC housing.
Be sure to pin the rear pinch clamp, though, before beginning to reinstall.
#40
Didn't Bill exchange an auto TT without transmission removal by removing the top engine bellhousing and working it around? I've seen the post, and even thought about doing it that way, but I chose to do it the standard, slow way and take it all apart and then have to clean and replace everything before reassembly... It can be done, but it's not as easy as it sounds I believe.
#41
Then a couple weeks ago he was revisiting that experience with somebody else here. There seemed to be an issue. It was a good discussion, but I can't seem to re-locate it.
#42
Rest in Peace
Heaven forbid a mechanic make a living. I do not blame him a bit for not wanting to put parts on that he has no knowledge of, his rep is on the line.
In twenty years I have yet to have a customer supplied part fail, it is always "Them guys down at Greg's put it in wrong" and that is just one of the reasons that I almost never use a supplied part.
Wow.. All I can say is never let another touch your car.
My 'friend' who has a Porsche shop wants to charge me 800 bucks to install my torque tube.
Says its 10 hours of labor. Wow. Im planning to do it on my back in the garage this weekend. We will see (This is the same 'friend' that wanted 2k and change for a timing belt replacement (Oh and would not use Porkentensioner since he 'hadnt heard of it')
#43
Ain't it the truth. Very closely related to X$ shop rate, 2X$ if you watch, 3X$ if you help. You could maybe add, "your parts used for 2X the standard parts price + no guarantee". Actually I wouldn't even do this.
#44
To be fair, that mechanic probably didn't know very much about 928's. Would you install parts supplied by our Rennlist venders?
#45
(Shop supplied parts do fail too)
My disclaimer - I have had very few issues with installed parts of any origin, only with failed installations.
ex: thrust washer on backwards destroying AC pulley.
