Phenolic S3 Intake spacer?
Inventor
Anyone have access to phenolic and a CNC/waterjet?
Free when made @ work?
Is that exactly the measurements of the S3 port?
Inventor
It's exactly the size of the paper and metal gaskets. The ID is about 1mm larger all round than the head ports. The intake legs vary in ID, some are 2-3mm smaller in places than the gasket and are not oval.
I don't think I gasket matched the intake legs as much as I could have. Next time I have the intake off I will.
Inventor
I found I can't get over 300 rwhp/tq with airbox/MAF/plenum temps over 90°F. Back in December when I made 312+, it was stuck around 280 until I managed to cool the intake down from >130°F to ambient, 70-80°F. Once the intake cooled, the numbers just kept going up and up.
I'm going to
isolate the intake with a phenolic spacer
use studs for the intake, and isolate the nuts
use a bilge fan to blow cool air on the MAF, and into the valley
cover the top rear of the engine fan so it doesn't blow up over the engine
I'm going to
928 Collector
cooling the top of the engine while the bottom is hot may not be healthy?
what about radiant heat?
why not use incoming, directed airflow ... via the hood
dig a hole in your hood ...
Inventor
Is it going to catch a cold?
I don't think you'll be able to make it super cool, anyway.
Hot engine + cold air = good. Back in December, my thermostat was stuck(?), and my temps were near the upper white line (never higher). With a 75C, they were just above the first line, and with the 83C I have now, it's just below the tween of the lines. That's with the (superior) belt driven fan on all.
I already have the rear hood seal out, and that helps somewhat, but it's at city speeds that there's not enough airflow into the V. Cruisin', the internal airflow keeps it cool.
I have a spare hood which I've considered going (931) on, but probably won't...
Ken, I should be able to machine your parts. I don't have much time to talk today (swamped at work) but am happy to make them for you on a weekend. Send me an e-mail and we can figure it out if you're interested. I might, might have some material, but you'll probably have to send it to me.
although this probalby isn't what you had in mind with your hood, a picture of what I'm working on to alleviate underhood temps. No testing involved, just fun.
Ben
Ben
Ben - do you have access to a CNC machine as well?
Did you by chance see my "Screw it: Sheet metal intake" thread?
Thanks!
