928 Forum 1978-1995
Sponsored by: 928 Specialists
Holber race car gets a new engine. Progress Report
Old 08-06-2008, 09:01 PM
  #61
mark kibort
mark kibort's Avatar
uh oh, no time. cant build the engine this weekend unless i have the heads on the car. how critcal is it to use the spray??
mk
Originally Posted by BrendanC
You have to order it online. Look for Hylomar blue spray can.
Old 08-06-2008, 09:07 PM
  #62
soupcan
soupcan's Avatar
Originally Posted by mark kibort
There is one in between. a later stud and nut version that used the angle torquing and shows 90 90 and then another 90!
anyone that has done this care to comment. an extra 90 is a LOT of extra force that I wouldnt want to be without!
mk
If you are using bolts why worry about the specs for nuts/studs? Go with the specs for the bolts.
Old 08-06-2008, 09:16 PM
  #63
soupcan
soupcan's Avatar
mk
I found it for an 85 5.0l with studs 20nm/90/90/90 followed by only in conjuction with new stud bolt. A TSB was issued for all torque specs on all heads I am reading it now, it included the above mentioned procedure.
Old 08-06-2008, 09:20 PM
  #64
soupcan
soupcan's Avatar
Default Here you go...
This technical information replaces all previous instructions in repair publications concerning the tightening of the cylinder heads on the 928, 928S and 928 S4.
First Version
From Model introduction 1978 up to 1983 models engine numbers:
81 D 0812 - M 28/19 manual transmission 81 D 5829 - M 28/20 automatic transmission
Cylinder head studs black-grey color short threads (A in Picture 1).
Tightening Specifications:
Step 1: 20 N-m (15 ft. lbs.)
Step 2: 50 N-m (37 ft. lbs.)
Step 3: 90 N-m (66 ft. lbs.)
Important:
Tightening sequence must be kept for each step (Picture 2). Bearing surface of the cylinder head nuts and threads must be lightly coated with oil. Never use lubricants between washer and surface on the cylinder head. Washers must not turn while tightening. Create a reference mark if necessary.
Cylinder Head Gaskets
4.5 1 engine types M 28/03 and 04, M 28/13 to 16
Part Number Right side 928 104 371 11 Part Number Left side 928 104 372 11
4.7 1 engine types M 28/19 and 20
Part Number Right side 928 104 361 06 Part Number Left side 928 104 362 06
Cylinder Head Nuts
Part Number 999 076 028 02
Washers
Part Number 928 101 301 02
Second Version
From 1983 Models beginning with engine numbers:
81 D 0813 - M 28/19 manual transmission 81 D 5830 - M 28/20 automatic transmission 81 F 0050 - M 28/43 32 valve manual trans. 81 F 0560 - M 28/44 32 valve automatic trans.
Cylinder head studs gold-yellow color longer threads (N in Picture 1).
Tightening Specifications Torque Angle Method:
Step 2: 90 degrees (1/4 turn)
Step 3: 90 degrees
Step 4: 90 degrees
Important:
First version studs (A in Picture 1) were used in production from July 21, 1983 to September 6, 1983 (1984 Model cars). Engine Numbers:
81 E 00097 - 00113 M 28/19 manual trans. 81 E 05194 - 05307 M 28/20 automatic trans.
When repairing these engines, it is especially important to remember that cylinder head tightening specifications from first version are applicable.
However, if new studs (gold-yellow) have been installed on older engines, the torque angle tightening method is applicable.
Important:
Tightening sequence must be kept for each step (Picture 2 - 16 valve, Picture 3 - 32 valve). Bearing surface of the cylinder head nuts and threads must be lightly coated with oil. Never use lubricants between washer and surface of the cylinder head. Washers must not turn while tightening. Create a reference mark if necessary.
928S 16 valve engines
928S 32 valve engines
Part Number Right side 928 104 367 02 Part Number Left side 928 104 368 02
Cylinder Head Studs
Part Number 928 101 187 06 (193 mm) Part Number 928 101 186 04 (142 mm)
Washer
Note:
New cylinder head nuts (12 mm high) must be used for each repair in conjunction with the torque angle tightening method, even on older engines.
Third Version
928S engines with hexagon head bolts from April 1986 engine numbers:
81 G 00705 M 28/43 manual transmission 81 G 06827 M 28/44 automatic transmission
Step 3: 90 degrees
Important:
Tightening sequence must be kept for each step (Picture 4). Bearing surface of the cylinder head bolts and threads must be lightly coated with oil. Never use lubricants between washer and surface of the cylinder head. Washers must not turn while tightening. Create a reference mark if necessary.
Cylinder Head Bolts
Part Number 928 101 231 00 - M 12 x 180 Part Number 928 101 233 00 - M 12 x 130
Washers
All engines up to 1986 models
Part Number 928 101 301 02 (25.8 mm dia.)
From 1987 models
Part Number 928 104 229 00 (27.7 mm dia.)
Note:
Hexagon head bolts can also be installed in older engines. Threads in engine block must be cleaned when replacing studs with bolts. Torque angle tightening method in three steps is also applicable to older engines in conjunction with hexagon head bolts. Hexagon head bolts can be reused in repairs.
New washer, Part Number 928 104 229 00 may not be used on engines before 1987 model year (see sketch).
Old 08-06-2008, 09:24 PM
  #65
mark kibort
Well, that just about says it all! Thanks!!!! I saw it too, but was wondering why the early bolt motors would use the (3) 90s vs the newer engiens using only (2) 90s. i guess it follows the bolts
mk
Old 08-06-2008, 09:28 PM
  #66
Bill Ball
Under the Lift
Bill Ball's Avatar
Originally Posted by soupcan928
I am looking at alldata and the 5.0l is 20 then 90and90. For the early stud/nuts I see 20nm/50nm/85nm -leave preload for 30min then loosen all nuts 1/4 turn and then final tighten all to 85nm.
The 20/50/85nm is very early only. There was a small change with a new gasket to end at 90nm starting in 1980. The longer studs starting in 83 are 20 followed by the 3 torque angle steps.
Old 08-06-2008, 09:36 PM
  #67
90 S-4
90 S-4's Avatar
Default Spray
Mark,
Skip the spray, if your surface finish is correct then you don't need it -- I was
told that by the tech guy at Hylamar. It's been used as an aid when race teams
didn't have time to resurface to spec and the surface was a little rougher than
desired. I'd be more concerned if I was you about following the proceedure
the WI guy's gave you re: torque specs. I really think you should use an OEM
gasket !
Old 08-06-2008, 09:45 PM
  #68
Bill Ball
Under the Lift
Bill Ball's Avatar
That bulletin is not in Jim Morehouse's collection. I wonder what that last line means to Mark's situation. He's using 87 heads (on an 85 block), so I assume it's not relveant.
Old 08-06-2008, 10:16 PM
  #69
soupcan
soupcan's Avatar
Here is the sketch for the washers
Old 08-06-2008, 11:27 PM
  #70
the flyin' scotsman
the flyin' scotsman's Avatar
Mark...........can you post pics of the refurbed heads?
Old 08-07-2008, 04:23 AM
  #71
mark kibort
Ill try and do it in the morning. Bill came over and we spend some time looking at the holbert motor again. no squriters by the way!
we finally got to work and put the heads on.
oil pick up and new gasket with pan on
oil pump on
Heads on
should have the cams on tomorrow night.
Lots of cleaning of the timing belt covers and intake left.(the tough stuff )
mk
Old 08-07-2008, 10:41 AM
  #72
Tom. M
Deleted
Tom. M's Avatar
Not too surprising....the lack of squirters along with your short shifting is likely what has kept the 2/6 together.. Have you pulled that piston yet?.
oil pump on
Heads on
mk
Old 08-07-2008, 02:11 PM
  #73
BC
BC's Avatar
The hylomar is an extra step to ensure good seal
Old 08-07-2008, 02:45 PM
  #74
Bill Ball
Under the Lift
Bill Ball's Avatar
Mark should have some pictures...
- The head finish looked nothing like Brendan's photos whereas the block mating surface did.
- Mark said Todd recommended TWO torque sessions for the Cometic gasket, relaxing the torque in-between. I've not used Cometic tri-layer metal gaskets. It is true that the feel of the first torque session was very strange compared to the stock gasket. It took almost no effort to do the second 90 degree angle. The second torque session felt just like torquing a stock gasket.
I was not comfortable with any of this, but I'm not sure how we would get any more comfortable. People can criticize, but Mark has to rely on the advice of the builder and his available resources. The machine shop insists they got the head finish right, so there we are.
BTW, the throttle switch worked like new and it is true that the 21 year-old intake seals looked and felt as if they were new.
Old 08-07-2008, 02:53 PM
  #75
AO
Supercharged
AO's Avatar
Did it look better or worse?
Quick Reply: Holber race car gets a new engine. Progress Report
