Cam timing off on driverside
I just set up the timing tool and found this pass side at 0 Driver side who the hell knows. Seems like I ned to move the cam over a couple of teeth, any feed back, how far off is this ?
Inventor
Was the engine cold?
Inventor
2° isn't much, and it will take some work to make it right, but if you want it to be purr-fect, then reset the passenger side.
The most effective method for perfection I've found is to set the timing, spin the engine with the starter (EZ-? disconnected) to equalize the belt tension, turn the engine back to O|T #1, and check both sides again (repeat ad nauseum).
