coil earth
coil earth
hi, just a quick question. as you look at the car from the front my left hand coil has the earth strap hanging down and attached to nothing. its fixed to coil bracket but where does the other end go.
Assume it's an S4/GT or GTS. The earth strap bolts to the engine lifting bracket with an M6 bolt. Engine lifting bracket is just aft of the drivers side (UK RHD car ?) distributor cap fastened to the side of the cylinder head. The hole for the M6 bolt is behind the big hole that you would shackle a chain to if you were lifting the engine.
If it's not an S4/GT/GTS - I've no idea
thanks very much. yes its a 89gt uk car, just changed all the coils caps and rotors due to a bit of a miss fire and found that lead just hanging down, so im sure that don't help. only had car a short time and cleaned alot of earth points but not there! cheers
hi, yeah i had a look at that thanks, its all done now but still abit lumpy on idle and a bit jerky at low revs! it seems i will have to look into this abit more
Team Owner
make sure the injector connections are all good IE a connector not falling off the injector
