Injection Labs rebuilt MAF will be here on Friday,A Question?
The 85-86 you mave a manual fine adjustment for the mixture as well as a manual idle screw. The later LH 1987-1995 BOTH are computer controlled. The workshop manuals detail the adjustments.
I used CRC MAF cleaner - it did a great job (got it at the local NAPA store)- the very fine platinum wires looked like new. There is a thread on it here too, where one guy cleaned his MAF while still in the car (I wouldn't do that tho - easy enough to just pull it out). Plus, I replaced all rubber, including seals in throttle body and at the MAF.
I thought I read somewhere that we should not use a MAF cleaner on our cars? I have that stuff that I clean the BMW's MAF and then I used it up on killing some wasps. It paralyses and kill those suckers in less than 3 seconds, lol.
Gio - here is one thread that I found. There was another where a guy cleaned the MAF while still mounted on the engine. I used the cleaner and I think it worked well on mine - made it look like new, and have driven many miles since with no issues...link: https://rennlist.com/forums/showthre...ning+maf+spray
