928 Forum 1978-1995
Sponsored by: 928 Specialists
Some pics of installation of S3-based cam in an S4 head
Old 04-14-2008, 08:31 PM
mark kibort
mark kibort's Avatar
Dennis, am i seeing things, or is your driver side exhaust cam lobe, opposite to mine when the indicator boss or mark is pointing up?
ah, never mind, you bounce back and forth with your driver vs passenger sides. that was the passenger side.
mk
Old 04-14-2008, 08:44 PM
mark kibort
is that the 968 stuff????
mk
Originally Posted by Sterling
I didn't either.... try it with no easy cut templates from the factory and intake cams that can advance 15 degrees and retard 15 degree's (depending on the bank) based on the amount of oil in the tensioner.......
Old 04-14-2008, 09:10 PM
Bill Ball
Under the Lift
Bill Ball's Avatar
20 degrees may sound like a huge error, but without the Porsche tool, when we eyeballed the alignment of the lobes versus a photo or our eyeball estimate of what the cam lobe separation should be, considering the included angles of the valves, we could make arguments a tooth in either direction. The arguments were between one another. If any of us were working alone we could have easily convinced ourselves things were right on.
Even on the pair with the alignment bosses, one of the bosses and been ground down so there was no tip left. It was not nearly so clear as in the shop manual photo.
We tried a variety of ways to improve our eyeball technique, including Mark's suggestion of figuring where the missing boss must have been from a comparable cam, but we kept getting inconsistent results. Again, it was hard to get all 3 of us to agree. I did not like any of these estimates. None of us really did. All of our eyeball estimates were +/- 10 degrees. There's your tooth error.
So, out came the dial gauges. With them, we could determine max lift repeatably within 1 degree unless we made some sort of boo boo.
Here you can see the extension Jim made to get the indicator on the lifter. The area you have to work with to get a shot at the lifter w/o cam interference is rather small, but it worked like a charm.
Old 04-14-2008, 10:36 PM
IcemanG17
IcemanG17's Avatar
Sweet work and pics guys!!!
Dennis your new and improved motor is really gonna be something!!! With the exhaust setup you have and some sharktuning you should be close to a NA 5.0L dyno record!! I think the current record is close to 350whp
Old 04-21-2008, 07:38 PM
Dennis K
Dennis K's Avatar
Quick update:
Yesterday, I replaced the old cam chains w/ new Iwis standard chains (racing versions were not in stock anywhere for months) and replaced the tensioner pads with new ones. With the old chains & pads, we had measured the lobe separation angle between the intake & exhaust at around 116º. After replacement, the LSA dropped to 113º on both sides, which is exactly what we wanted. It shows how just much of a difference replacing the stretched chains and worn pads can make.
By the way, the specs in the factory manuals show a 114º LSA for S3 cams and 110º for GT cams, so we're right in the ballpark.
Old 04-21-2008, 08:19 PM
BC
BC's Avatar
Wow.
Old 04-22-2008, 04:40 PM
atb
atb's Avatar
Pretty marked difference. Will be interesting to see how your motor reacts.
Narrower LSA in very general terms means a little rougher idle and more bottom end? Then again, you've got bigger lobes now than a stock S4 so I guess you get more all around.
Old 04-22-2008, 04:50 PM
Bill Ball
Under the Lift
Bill Ball's Avatar
And I will add that Dennis' pads were not terribly worn. The chain groves on the "tight" side were pretty shallow, far less than most people would think indicated replacement, and the "loose " side pads were unworn.
Old 04-22-2008, 11:38 PM
Dennis K
Dennis K's Avatar
That's right Bill, I forgot to mention that. I should have taken a pic of the old pads.
Old 06-28-2008, 07:21 PM
drnick
drnick's Avatar
do you guys have an update on the installation and running? ive just been driving my car after installing the cams as per jims timing recomendations... will aim to dyno later this week. only touble for me is tha ive installed headers at the same time so i cant tell what has done what. im guessing ive gained 30 bhp total but we will see. the big question in my mind is whether the timing needs altered any further??
Old 06-28-2008, 08:56 PM
Andre Hedrick
Rest in Peace
Andre Hedrick's Avatar
Dennis and Bill,
So that what was in the boxes I gave NorCal 928?
Old 06-28-2008, 11:23 PM
Bill Ball
Under the Lift
Bill Ball's Avatar
Andre:
You mean the Porsche engine support tools? They were well-used on this project. THANKS!
nick:
Dennis should come in and report, but he has been having too much fun driving his car. It screams. We have done some seat-of-the-pants dyno runs on the local freeway and it feels very strong. Dennis had headers already, and these cams added some power, along with the lightweight lifters . We were going start Sharktuning today, but we still need the early style diagnostic connector cable to do that (on backorder). We plan to get to the dyno in a couple of weeks.
Old 06-29-2008, 12:17 AM
Jim Morton
Jim Morton's Avatar
Nick:
As Bill already mentioned, Dennis' engine is running well. The AFR readings are not too far off and we did use 24# injectors from the get go with these cams/headers/etc.
Given how Dennis' engine runs, I have had the same cam profile ground on a set of GT cores with the narrower lobe centers, all on a shift of the intake cam. I will install these cams into my GTS later this summer. In the mean time, I now have a Sharktuner setup and am working on getting a good handle on using it. As Bill mentioned, we are getting it wired for the 12Pin style diagnostic connector as opposed to the 19P connector sent with the ST. Once past this hurdle, we'll begin tuning in Dennis' engine. From there, I dive into my GTS !
Old 06-29-2008, 01:17 AM
Andre Hedrick
Rest in Peace
Originally Posted by Bill Ball
Andre:
Cool, I have never seen them before and this was a first!
Old 06-29-2008, 02:14 AM
Dennis K
Dennis K's Avatar
Dr. Nick -
The motor has been installed. Go to this thread for an update (with video):
https://rennlist.com/forums/928-forum/428483-5-0l-track-motor-build-is-finally-done.html
The car runs extremely well. The pull at 5000 rpm seems greater than at 4000 rpm. We're just starting down the road of Sharktuning. As we get further along I'll update the above thread.
Andre -
Many thanks for the engine support stands. Go to the thread I linked above to see more pictures of your donation in action. It made life a lot easier having those pieces.
Quick Reply: Some pics of installation of S3-based cam in an S4 head
