track car - alignment. what do you think?
Just got the track car back from alignment and got the Hunter printout attached.
What do you guys think?
Under the Lift
Wow, was your front toed-in before. And with the rear toe and front caster all uneven, the car must have been a a handful. Ready to race now.
the only thing to do is go out on track and see how it handles. keep a dairy of tire pressures and temps from the inner, middle and outer sections of the tires - front and rear. i predict you will have trouble getting heat into the outer third of the rears with this much camber - its what im running and thats my experience. im less certain on how much rear toe is required, it seems opinions vary. did you get the alinement with a half tank of gas or a full tank? this can affect the rear geometry quite a bit.
i think the front can probably take more camber for an all out track attack but otherwise i like the front toe and im guessing you maxed out the front castor? it seems some cars have more ajustment here than others.
but I got a hot lead on an '85 LSD box.
I replaced the steering rack, that's why the toe in was way off.
the tank was half full and no one in it...
So I need to buy a temp gauge.
thanks,
For anyone in South Florida by the way, Expertech in Sunrise is a great place for alignment. They have a Hunter 600 alignment rack and charged me $107. took them about two hours.
the only way I will get more camber in the fron is by changing upper A arms and that is not in the budget for now. At least that's what I have found out.
I was told to start with no toe in the rear or a tick of toe in to start and take it from there.
you dont need more camber in the front. both anderson and i took much of the camber out of the front and rear and got better handling and wear. ESPECIALLY Anderson, who had a bunch more camber in the rear and was real loose and was burning up the inside edge. im near 2 degrees on all 4 corners.
rear toe might make you a little loose under power. (that coupled with the 2.5 degree rear camber)
remember, you are not setting up a 911 or BMW
You will see at the track.
Mk
Mk
