Brake Pressure Warning Light
My brake pressure warning light began flashing on my 79 AT. Plenty of fluid, good brakes. What does it mean when the manual says circuit failure? Can it be driven? Suggestions on the fix?
Thanks.
Thanks.
Could be a failure starting to occur, or just one or both of the pressure switches went bad. The pressure switches are screwed into the master cyl.
You will need to bleed the brakes once you replace these switches.
Good luck.
Good luck.
