928 Forum 1978-1995
Sponsored by: 928 Specialists
looks like I need to pull a rabbit out of a hat. 12mm - 1.5 bolts
Old 03-15-2008, 10:22 PM
Shark Attack
Shark Attack's Avatar
Default looks like I need to pull a rabbit out of a hat. 12mm - 1.5 bolts
I brough home an extra drivetrain last night. I went to put the engine on the stand and needed longer bolts. I went to Lowes and Home depo and none carry a 12mm Bolt in a 1.5 pitch. I looked breifly on line at "Bolt Depo" didnt even have them. Anyone else run into this problem? Tomorrow I will start my easter egg hunt all over.
Old 03-15-2008, 10:24 PM
dprantl
dprantl's Avatar
http://www.mcmaster.com/
Dan
'91 928GT S/C
'86 928S 5-spd w/LSD *sale pending*
Old 03-15-2008, 10:27 PM
rixter
928 OB-Wan
rixter's Avatar
go to your local european service shop, bet they have them
Old 03-15-2008, 10:33 PM
Shark Attack
man I hope so. The thing is sitting on a friends truck and its not moving until I find these bolts. Rick, I also see on my blk berry you sent me an email. I dont have my PC so i do not have my email. Ill get to it in Monday.
Old 03-15-2008, 10:44 PM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,813 Likes on 1,372 Posts
Maybe I'm remembering wrong, but wasn't there a relatively recent thread on engine stands where someone used bolts from the car (lower control arm bolts?) on their engine stand? This doesn't work for you if it's an 'extra' motor, but there's probably a spare chassis where you got your spare drivetrain?
Old 03-15-2008, 10:47 PM
FlyingDog
FlyingDog's Avatar
Check your local hardware Ace or unbranded hardware store. They usually have more in the way of nuts and bolts. If you can't find it there or with Rxter's suggestion, McMaster-Carr should be able to get it to you easily in 1 day. My dad has actually ordered from there with ground shipping and it was delivered same day (NJ warehouse to MD house).
Old 03-15-2008, 10:49 PM
928ntslow
928ntslow's Avatar
Ace Hardware. Thats where I got mine.
Old 03-16-2008, 01:16 AM
crackerfeet
crackerfeet's Avatar
Fastenal?
Old 03-16-2008, 01:45 AM
David L. Lutz
David L. Lutz's Avatar
You are correct there was a thread on this and I can't seem to find it. The guy was using a couple of bolts from the front supension I think.
I know because I checked about 6 different hardware stores and none had the correct threads and ended up ordering them from BoltDepot.com Part #6344. ( I had ordered them before I saw the thread we are refering to)
PS: I order them from www.boltdepot.com because they were only $2.52 ea.
Old 03-16-2008, 01:51 AM
FlyingDog
FlyingDog's Avatar
Most of the suspension is either 12x1.5 or 14x1.5 nuts and bolts.
Old 03-16-2008, 04:16 AM
jon928se
jon928se's Avatar
Front wheels, lower control arm, front mounting bolts should be more than long enough and they ARE M12x1.5 . Bolt length is 100mm (underside of head to end bolt) thread length is 30mm.
You may need a whole stack of washers between the bolt head and the engine stand mount (1/2" will work well available from HD no doubt) depending upon how long the hole in the engine stand mount plate is.
Borrow 1 from each side of your 928 - you can probably just about get them out with the 928 on its wheels. DONT DRIVE YOUR 928 WITHOUT THEM. When you get two new bolts just put the new ones into your 928. This will let you get the motor out of your friends truck quickly, just leaves you without a 928 until you get the replacement bolts.
Edit - PS by only removing the one bolt from each side of the car you shouldn't affect your alignment.
Old 03-16-2008, 08:18 AM
M. Requin
M. Requin's Avatar
Originally Posted by crackerfeet
Fastenal?
+1
Old 03-16-2008, 11:42 AM
Shark Attack
Ace was the place!
Old 03-16-2008, 12:03 PM
Brett Matthews
Brett Matthews's Avatar
Here in Columbus, there is a local business, called Metro Industries. When I am blocked by easy access to any metric bolt size and pitch, I end up going here. They haven't failed me yet. Rare as I've needed to use them.....
McMaster-Carr, sure, but you have to wade through their massive super-thin paper catalogue, and be charged three to four times the cost, if you could find the part locally.
Some people, because of their rural location, will be stuck with this 'option'...
Old 03-16-2008, 08:28 PM
David L. Lutz
Can't believe you found it at Ace. Good for you!
Quick Reply: looks like I need to pull a rabbit out of a hat. 12mm - 1.5 bolts
