928 Forum 1978-1995
Sponsored by: 928 Specialists
Blown 5.0L Hybrid pics
Old 03-05-2008, 10:57 PM
toofast928
toofast928's Avatar
Default Blown 5.0L Hybrid pics
My winter project. Hope to start by May.
Old 03-05-2008, 11:01 PM
Lopez
Lopez's Avatar
Cool! What exactly is hybrid about it?
Old 03-05-2008, 11:02 PM
soupcan
soupcan's Avatar
Sweet.
Old 03-05-2008, 11:05 PM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,069 Likes on 1,181 Posts
Hybrid = 16V top on a 32V (5.0) lower.
What compression ratio did you build?
What lower end is that?
What EFI are you running?
DETAILS MAN, WE DEMAND DETAILS!!!!
Old 03-05-2008, 11:06 PM
toofast928
toofast928's Avatar
Lopez,
5.0L short block, 16v USA heads.
Old 03-05-2008, 11:08 PM
toofast928
toofast928's Avatar
Hacker,
9.7:1 CR. Pistons have been dished and ceramic coated. 1985 short block. Using L Jet.
Old 03-05-2008, 11:11 PM
SeanTT
SeanTT's Avatar
My car already scares me...so I can't imagine what yours would do to me. I'll bring my own platic seat cover when you take me for a ride.
Old 03-05-2008, 11:23 PM
hacker-pschorr
Originally Posted by toofast928
Hacker,
I'm assuming you started with 85/86 pistons then?
L-Jet??? We need to have a chat.....
I'm starting to put the details together on a similar project. I recently aquired all of the parts, now it's assembly time:
S4 lower end (swain tech coated pistons)
EuroS heads / intake / TB (swain tech coating on combustion chamber & valve faces)
78-79 Cams
Maybe a custom intake manifold, not 100% sure yet.
LH / EZK
Boost level to be determined. No less than 20psi
Old 03-05-2008, 11:57 PM
toofast928
toofast928's Avatar
I'm only gonna run 8-9 # boost. L Jet should be fine with BEGI help. Next year the plan is to convert to MAF.
Wait till you see the air filter set up................
Old 03-06-2008, 01:49 AM
BC
BC's Avatar
Hacker,
86. Unless you didn't use the one I sent you.
Old 03-06-2008, 01:51 AM
BC
BC's Avatar
78-79 Cams
LH / EZK
You could run 30psi if you used the right fuel.
Old 03-06-2008, 04:41 AM
928ntslow
928ntslow's Avatar
You sure you won't lose 50hp with that crank pulley?!?!
Old 03-06-2008, 08:23 AM
hacker-pschorr
The only thing keeping me from running 30psi now is my supercharger. We'll see, if I'm able to hit 500rwhp with the new motor and my current blower, I'll leave it.
Old 03-06-2008, 08:44 AM
AO
Supercharged
AO's Avatar
Wait a minute, did you ever check pressure before the barn door? I've got to think that your bottle neck is the barn door, not the SCer.
Old 03-06-2008, 09:00 AM
Mike Simard
Mike Simard's Avatar
That's Gorgeous! The light gray really looks good.
Quick Reply: Blown 5.0L Hybrid pics
