What length bolts for engine stand?
On the Bandwagon
Getting prepped for the engine pull.
I used to have a set of bolts but can't find them, so I'll go ahead and order some new ones from McMaster-Carr.
IIRC they are 12x1.5, but what length do I need for the blind holes and for the through holes.
I just used to two top bell housing bolts with a couple of extra washers for the top and then found a couple of others in my "bolt storage bin" for the open bottom holes.
Rod
Rod
Got those bolts at BoltDepot.com Metric hex bolts, Metric standard bolts, Steel grade 8.8 fine thread, 12mm x 1.5 x 120mm. 120mm was a bit too long, so I used lots of washers.
I have a pair of really nice grade 10 i think they are bolts that thread into the upper 2 holes in the block if someone wants to buy some from me
Lets say $12 shipped (they were pretty expensive as i recall)
I think your wasting your time asking as not all engine stands are the same. What you need to do is measure the 4 hole lengths of the engine stand (should all be the same, but you never know) and the length of the hole at the bell housing , then add 3/4" -1" of thread length for the through bolts and your measurement is the length of the bolt shaft, not the head. I ended up with 5 1/2" bolts for mine. Get 2 washers and 1 nut per bolt for those. The top ones you need to take the engine stand hole measurement and add 3/4" -1" of thread. You need only 1 washer each for these on the bolt head side. I think I ended up with 4 1/2" for these, but really don't remember. Just go measure...3 minutes of your time.
