928 Forum
Sponsored by: 928 Specialists
Hydralic -VS- Bi-metal plate tensioners
Old 02-05-2008, 12:25 PM
--JR--
User
--JR--'s Avatar
Question Hydralic -VS- Bi-metal plate tensioners
I've been encouraged to upgrade my old bi-metal tensioner to a hydralic one when I do the timing belt.
I'm a little relicatant because a mechanical spring plate I would think to be more reliable then a static hydralic cylinder. Plus my 78 doesn't have the wiring to show a tension light should a problem arrise with the hydralic one.
Looked in the last two years of tensioner topics and didn't see any disscussions on this.
Thought's?
--JR-- is offline
Old 02-05-2008, 12:30 PM
FlyingDog
Super User
The 'hydraulic' ones aren't hydraulic. They both use bimetallic washer stacks to set tension. The 'hydraulic' version just adds oil flow to the block for better lubrication and heat transfer.
FlyingDog is offline
Old 02-05-2008, 12:38 PM
Jim bailey - 928 International
There is no oil flow...only the oil you pour into the tensioner after it is bolted to the block. And the oil in the tensioner with the o-ring just acts like a shock absorber to control flutter. All the 928 tensioners are mechanical and actually are "detensioners". The only adjustment they make is as the washers get warm it loosens the tension. That keeps the belt from getting tighter as the aluminum engine expands. When you set the tension bolt and lock nut it never changes. There is no hydraulic 928 tensioner.
Jim bailey - 928 International is offline
Old 02-05-2008, 02:30 PM
PorKen
Inventor
PorKen's Avatar
If by 'hydraulic', you mean a sprung/damped tensioner, like on the Porsche 944/968, they are self adjusting. They automatically reset up or down to the ideal range of tension. Unfortunately, when they designed the 968 tensioner system, they didn't bother to redesign the tensioner for the GTS.
It's the stock tensioner which supplies (in practise) a static tension, which leads to overtensioning, and reduces the life of the gears, and water pump bearing. But, most often, trouble with the 928 tensioner system isn't because of the tensioner itself. It's the weakness in the design of the rest of the parts, ie: weak shoulder bolt, plastic bushings, long offset tensioner arm, pulley w/small bearing, etc., which lead to belt tracking problems or loss of tension. Because of problems keeping the tension constant between hot and cold, and new to old belt, Porsch kept adding idler pulleys to try and control the belt.
In any case, AFAIK, it's highly unlikely that a '78 would suffer any valve damage from a timing belt slip or break.
PorKen is offline
Old 02-05-2008, 02:34 PM
928fan4life
User
928fan4life's Avatar
Porken
Do you still sell that timing belt tensioner setup that you made? Looks alot easier to use than the factory stuff.
928fan4life is offline
Old 02-05-2008, 02:50 PM
PorKen
Inventor
PorKen's Avatar
928fan4life
As I am not a Rennlist 'sponsor', I may no longer promote any 'products' I may or may not make, nor include a link to any 'commercial' webpage in my signature, so as not to offend paying 'sponsors'.
I'm cool with that.
PorKen is offline
Old 02-05-2008, 03:34 PM
the flyin' scotsman
the flyin' scotsman's Avatar
928fan4life..............there are quite a few of us on the North side that have the non OEM tensioner installed with great results.
there is a web site somewhere; oh yeah:
http://liftbars.com/
the flyin' scotsman is offline
Old 02-05-2008, 04:06 PM
JHowell37
JHowell37's Avatar
PorKen can't promote his site here, but what I can say is that there is a rather informative site out there that discusses a hydraulic tensioner for the 928. Go to yahoo. Type in liftbars.com and you will find a link with information.
JHowell37 is offline
Old 02-05-2008, 06:37 PM
928fan4life
User
Good to know! I hadn't heard anything in a long time about this tensioner and I am wanting one.
Old 02-05-2008, 09:13 PM
--JR--
User
--JR--'s Avatar
Ok, now that we've established that the hydralic one is really more like a shock and there are aftermarket ones available... I am most interested in knowing about stock 928 tensioners only. The diference between the oil filled and non-oil filled versions. Is one really any better then the other?
Should I be worried about "upgrading" from one to the other if I'm doing a front engine re-and-re?
Thanks in advance!
--JR-- is offline
Old 02-05-2008, 09:39 PM
PorKen
Inventor
PorKen's Avatar
They are all oil filled. The later ones which have bleed ports, and can be re-filled are better.
Note that there are a couple different tensioners, with different offsets, and matching tensioner arms. You cannot mix and match. There are a few threads on this.
PorKen is offline
Old 02-05-2008, 09:47 PM
Randy V
Randy V's Avatar
Originally Posted by PorKen View Post
928fan4life
I never said that, Ken.
I have no problem with you 'mentioning' your tensioner, as it does not compete with a similar product sold by a paying Sponsor.
So there.
Randy V is offline
Old 02-05-2008, 09:54 PM
PorKen
Inventor
PorKen's Avatar
If you say you didn't say it, then OK...you da boss. I thought it was 'an offa I couldn't wefuse'.
I'm still gonna keep it cool, so it doesn't look like I'm getting a 'free ride'.
Fuhgedaboudit.
PorKen is offline
Old 02-05-2008, 10:19 PM
Lizard928
Super User
Lizard928's Avatar
Just an FYI I just installed the second porkensioner in an 87 5 speed, works perfectly right outta the box,
thanks again Ken.
Now I have to do the 87 auto.
Lizard928 is offline
Old 02-05-2008, 10:26 PM
the flyin' scotsman
I'vd said this before...........Kens product advances what Porshe designed in the mid '70s.
For any folks that have modern m/cycles look at how they do the same; and have done for many years.
Quick Reply: Hydralic -VS- Bi-metal plate tensioners
Contact Us - About Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
