Stroker with factory ECU's-will it work?
Some of the F-1 engines mounted the injector ABOVE the bell of the air horn ! and the storm going into the engine carried the fuel... Porsche race engines they moved them up down pointed up and pointed down
We could have a long, interesting discussion on the subject of injector placement as well as throttle opening direction but in the end it's not as important as you might think. If you're using a stock ECU then it's batch firing which makes injector placement even more irrelevant. The fuel is going to be puddling on the walls and it doesn't matter too much because it will be evaporating anyway.
Hammer,
Hammer,
Hammer
Hammer,
Hammer,
Hammer
It was just a comment. I have never designed an intake manifold so i trust your judgement.
I guess the longer track to the combustion chamber allows the fuel more time to mix with the air more completely. It looked fromt he pic that the injector is pointing at the wall of the runner though.
I know suzuki used twin injectors on some of its more recent GSXR's and one injector was pointed at something like a 45 degree angle to the runner as this caused some sort of fueling anomality that they found best for power. I am sure they know allot more about this then i do that for sure.
Hey if your doing it from scratch, best to take advantage of whatever you feel will work best. Thats half the fun of making your own stuff.
When will you finish this engine and run it? Youve been doing this for at least the past year now right?
Hammer
It's been more than a year. However long it takes to do it right is how long it will take. (right Mike?)I'm in no hurry.
