Driver's wiper
Driver's wiper
My driver's wiper has broken. It started up normally but fell back down to the off position. The passenger's side continued normally and works fine. Any ideas?
Pull the cap and make sure that the nut that holds the arm has not slacked off. Failing that, remove the gasket that seals the plastic undercowl pan, then the pan itself and have a look at the mechanical linkage while running the wipers.
Good luck.
Good luck.
I wasted a Rennlist "coupon" on something so simple. I tried to pull the cap up this mornig but I guess it was frozen shut. Both sides' retaining nut were loose. Thanks for the fix.
