Fog Light Lense Removal
I'm trying to replace a bulb on my 81 s. After I remove the glass cover there is a second spring loaded plastic cover. How do I remove this? I checked the manuals and it only said how to adjust the light.
As I remember, in the shop manual is mark the screws for adjustning and for fixing - You simply remove the lamp and you you get acces to the bulps - from the cackside of the lamp.
Use some WD40 for the screws, not to brake them!
Good luck
Good luck
