Wish this was around when we did my WP/TB--bolt remover
The Lady's Man
One end routes out a cone shaped space, then you flip it over and the threads grab and remove. If they used hard enough matrial it has some possibility.
Under the Lift
EZ-Outs use a much deeper tap hole and a very brittle --> SNAP! quite often. Unless you want to get into more trouble, avoid EZ-Outs. Use lefthand drill bits, welded on nuts or just about anything but EZ-Outs. The tool in question looks rather harmless but probably equally useless for the type of stuck stuff you might encounter on a 928.
Under the Lift
Official Rennlist
Borat Impersonator
Borat Impersonator
EDIT: now that I watched it again, i don't think its lafontaine, could be a soundalike
