Rear Axle Boot Replacement Complete - here's the pics
Dr. Bob's link to the Sears pliers is the same I bought. I got mine at Kragen for $15.99. It has an embossed crosshatch pattern on the tips that really grip the pointed end of the clip so it doesn't slip off. Worked beautifully!!
Agree! I can link the write-up here, but a website back-up would be great! Dwayne, can you do that or do you need someone to host it? I'd be glad to put up a Dwayne's Workshop for you on my webspace.
Also, my garage and I were complete mess after this job. You could perform surgery with your degree of clenliness.
Great write up.
I need to do this job and now I know where I am going to go for a refresher/reference material on the job.
Thanks for the extra time and effort to document this for the rest of us.
THANKS for checking out the post. The boot kit did not come with one but I wondered the same thing when it arrived. I also noticed that my original boots (still on the axle) did not have them either. I called Jim at 928Intl (the place I bought the kits from) and he confirmed they are not needed. Thinking about it, I agree. The boot isn't supposed to be filled with grease (only the joint) and the small end of the boot does fit snuggly on the axle. So I proceeded to install without the small clamp.
Under the Lift
Dwayne: Randy has immortalized your work. Congrats. I will throw up a webpage/site for you, and you can let me know what you think.
Great job Dwayne. You don't mention a helper, so to do an extreme messy job like that and still manage to produce such a complete picture file is totally impressive.
Given the amount, or lack, of experience you profess, you certainly win the award for "Most Fearless DIY'er" of the year.
I notice that you used anti-seize for the wheel nut threads and thread locker for the allen heads. Was that a WSM procedure? I thought I had read that anti-seize was recommended for both. I'm curious because I used anti-seize on Brians allen heads this weekend and I sure don't want to have created a run away axle situation.
I would think it's ok to re-use the circlip, but wouldn't a new one be more correct?
That must be an early axle, there is a different type of tin bearing cover on the tranny side on later axles.
Great write up of course.
It seems odd to me that there were so many changes in the halfshafts. I think these halfshafts might have started getting used in the 964, which were probably being built in '88, (or at least the ends, the shafts probably aren't the same length) and this seems like it was probably a quicker to put in versin of the halfshaft - not needing to mess with 4 gaskets (or 8 on an C4), would save a bit of work-hours. How's that for a theory!
And Dwayne - excellent work! We're glad to have you here! As I've mentioned I'm in the middle of this (I swear I'll finish up this weekend!), and your photos and descriptions have been extremely helpful.
928 Collector
Excellent work, thanks for sharing. Perfect documentary actually. I did this job and found it easy but time consuming. One wonders if adding the bolt on the clamp where the factory clamp had none will add a slight imbalance?
Thanks for the comment....next project I think I will ask my wife to snap some of the photos that require me to use both hands on the work item - I think it would improve the quality of the pics.
"1) Run axle shaft into wheel hub on wheel end (lubricate splines and threads with Optimoly HT).
2. Install socket head bolts on transmission end (axle shaft flange surfaces must not have grease)."
I didn't find any reference in the WSM to put anything on the allen head bolts. However, when I was reading the posts on the Nichols site regarding CV boot replacement/repair, there was a post there by Greg Kanderman that recommended using threadlocker on the allens. It made sense to me to have a little extra insurance that those allens stayed put. If I followed the WSM to the letter, I would have left the allens dry.
THANKS for asking!
