How do I take off my .. Intake?
Robert, Cool, Thanks I will. I will wait till spring if I can. Thats when I hope not to be traveling so much. I need to find a place to rent. that will let me work on the car. I need at least a car port to work in. I better start getting the stuff I need together. I'm not afraid, but I do want to be ready. Peace, Brittany Li
Hi Brittany,
I was trying to respond to your rear wiper post, but it went away during my response. So, here is the link to relay and fuse diagrams. This link has been very useful to me. http://www.928gt.com/928specs/85-86relay.htm
HTH
HTH
Thanks I'll check it out. The wiper moves but seems to slip past the control plate on the return pass. Yes want happen to that post? ??? Thanks Brittany
Hi Brittany,
The main reason for the fuse diagrams is that someone replied that there are 2 fuses for the rear wiper. Check 18 and 11. I don't know what happened to that post. Otherwise, be sure that the nut is torqued down tight. Then check that mechanical interfaces are engaging. You may be able to adjust hatch alignment better. It could be a worn or defective mechanism. The lower mechanism is spring loaded.
Let us know what solutions you find to various problems. We are always curious about that.
HTH
HTH
