928 Forum 1978-1995
Sponsored by: 928 Specialists
fuel non return valve - why?
Old 04-03-2002, 10:42 AM
johnb
johnb's Avatar
Question fuel non return valve - why?
1984 euro s 4.7l 16v (no cats) auto, wheel at each corner etc etc.
what is the function of the fuel non return valve?
does it affect the running of the vehicle?
i guess it has a purpose, but if the pump is running and the pressure regs and damper are doing their stuff.....what is the non return valve for?
johnb
Old 04-03-2002, 10:54 AM
Bryan
Bryan's Avatar
Post
Uh, non-return valve? Do you mean the check valve in the fuel pump? It's so the fuel lines and rails stay full of fuel. This lets them come up to pressure in less than a second so the car will start immediately. Otherwise, you have to wait for the fuel pump to send fuel all the way up the lines, into the rail, then pressurize it. When I had my 944 apart, it took at least 30 seconds for this to happen when I restarted it (I emptied out the fuel lines when I had the engine apart). I don't want to have to crank the car for 30+ seconds every time I start it.
The check valve is in the fuel pump. Do you have something else in your fuel system in the engine bay besides two regs and a damper? If so, I don't think it's supposed to be there.
Bryan
Old 04-03-2002, 11:38 AM
WallyP
Rennlist Site Sponsor
WallyP's Avatar
Post
A tight system should hold fuel pressure for a minimum of thirty minutes, and several hours is better. The fuel pump check valve (replaceable separately) is critical to this.
If the fuel pressure is held, the engine will start almost instantly. After the pressure bleeds down, it takes longer for the engine to start. If the system is allowed to drain, starting is very difficult.
Old 04-03-2002, 02:33 PM
dr bob
Chronic Tool Dropper
dr bob's Avatar
Post
Reinforcing Wally's discusson, another big reason is to eliminate vapor lock in the system when the pump is shut down. If the pressure is allowed to bleed down when the pump stops, heat in the engine bay will evaporate/vaporize the liquid fuel in the rails and injectors. On warm restart, all that vapor needs to passed through the nozzles or the fuel pressure regulator before liquid fuel is available at the injection nozzle again.
Old 04-04-2002, 03:58 AM
johnb
johnb's Avatar
Post
thanks guys
that all makes perfect sense.
the valve had stuck open in my car. resulting in a small delay in starting....i just thought this was normal. now it has been fixed it starts instantly.
btw: the fix was to clamp off the fuel return line for a second, a couple of times. this shocked the valve back to life. that and plenty of injector cleaner in the fuel. pressure now holds for about 1 hour, slowly dropping to about 30psi over night. before fix, it dropped to nothing instantly.
i love this car, all faults seem to have a logical solution (usually expensive tho'!)oh well, on with fault 873!
regards
johnb <img src="graemlins/beerchug.gif" border="0" alt="[cheers]" />
Old 04-04-2002, 04:13 AM
Normy
Normy's Avatar
Cool
John...
You'll find this exotic is exotic in that it is actually easy to work on~
Normy!
Quick Reply: fuel non return valve - why?
