928 Forum 1978-1995
Sponsored by: 928 Specialists
Jagers "speedmounts"?
Old 12-07-2007, 12:40 PM
PorKen
Inventor
PorKen's Avatar
Originally Posted by UKKid35
Having fitted one myself I recommend this is only done as a temporary measure and only if the sump contacts the crossmember. Even with hydraulic mounts that appear completely collapsed you don't always get sump crossmember contact.
The problem I had with my 86's collapsed mounts was the 1-4 side header hits the crossmember reinforcement arm. The rubber spacer stopped this.
Old 12-07-2007, 12:57 PM
paalw
paalw's Avatar
Originally Posted by Imo000
$35 + Shipping to Europe then you have to pay duty and taxes (it will end up costing you $100 at the end and you’ll wait fro a month)!! Just make your own. This is what you need to get and cut it to size:
nope. $46.70, exactly. (without shipping insurance, but what the hell)
Shipping is $11(got that confirmed), and no taxes or anything as long as you get the sender to mark the invoice "sample" and total value under NOK200 =(appr. $38)
done this a mill times.
BTW - how much is that truck??
Old 12-07-2007, 01:56 PM
Jim bailey - 928 International
Jim bailey - 928 International's Avatar
I have never seen one so bad that the sump hits the crossmember. Asked our guy who takes apart the cars 600 or so he did not ever see one where the pan hit the crossmember. Greg Brown has never seen the sump hit but I guess anything is POSSIBLE. As mentioned the heat shield exhaust to the brace will hit and vibrate like crazy...
Old 12-08-2007, 03:42 PM
chaadster
chaadster's Avatar
Oh, that's interesting. I never did check mine for pan to crossmember contact; I just assumed that was the source of the vibration! That's what I get for assuming, I guess!
So, the Speedmount does put some additional pressure on the oilpan and gasket. Damage to the gasket, evidenced by leaking, does not seem to be a foregone conclusion, however.
Thanks for the clarification on that, Jim.
Quick Reply: Jagers "speedmounts"?
