Cold start great, hot start lowsy.
My SE starts first time on the button from cold, but simply refuses to start when the cars warm until I disconnect the tempII sensor and pump the throttle.
What the hells wrong with it, it's very embarrasing.
have you tried replacing the temp II sensor it is possible that it has failed and is flooding the engine when starting hot.
if you have replaced it crank the car over and very shortly after cranking hold the throttle WO most cars have a floodclear threshold at 70% or greater throttle meaning that by holding it WOT will cut all fuel and let it ignite what it already has in there.
Team Owner
when was the last time the fuel filter was replaced?
has the check valve ever been replaced in the fuel pump?
How many miles are on the car ?
Have you checked the fuel pressure damper and the regulator(fuel), to see if they hold vacuum and if they might be leaking into the vacuum lines.
If the temp 2 doesnt clear things up try putting a can of techron in the tank with it half full , do lots of start and stop driving if the fuel injectors are leaking this might help.
The best approach is to follow the procedure in the workshop manual for the fuel pressure leakdown test, with a fuel pressure gauge attached to the rail test point.
The tests pin the problem down to:
- fuel pump check valve
- leaking fuel pressure regulator
- leaky injectors
Do you have problem starting immediately after shutting down a hot engine? That would suggest it's not leaking injectors.
Team Owner
see post 4
Temp II and fuel pump check valve are likely.......check the resistance of the temp II both hot and cold...if it falls within specs its okay...the easiest way to check it is just to pull the plug...but the best way is to check its leads at the LH plug...to make sure there isn't a short along the way
The fuel pressure check valve is kinda a PITA to change.....but also causes hot start problems by bleeding fuel pressure back into the tank (its a 1 way valve in theory).... If you have a fuel pressure tester, its easy to check the leak down rates against the manual......
The last theory is leaky injectors.....this is the hardest to narrow down, but isn't as common as TempII or check valve....
Rather than pumping the throttle try just holding it wide open. It could be the Temp II sensor but it also could be a leaking injector that bleeds down when you shut off the engine putting fuel into the intake that doesn't have time to evaporate on a hot start.
It's an '88. SE's are all '88.
Not heard about leaky injectors. Interesting, it's done just over 100K miles.
If I plant the throttle it starts but the starter makes a horrendous noise, due to being overrun by the engine.
It's stopped raining today so I'll try and get on to it today. New baby permitting.
