Tranny issues
Tranny issues
I have a 87 s4 and i have been having issues with my tranny , from a standing start if i punch it down it seems like it pulls hard but will not shift into 3rd it just seems like it revs up but thats all if i shut the car off and restart it cures the problem ,it only happens when i jump on it any other time its fine. It also has been weird in the mornings when its cold it doesnt seem to want to drop into gear untill i rev it up .. I was given some advice to get the tranny flushed and a new filter. does anybody have any other ideas..
thanks in advance
1bgdog
thanks in advance
1bgdog
No kick down switch , and the fluid level is fine.. runs fine when i dont jump on it but when i get on it it runs strong up to rev limit then doesnt shift into the next gear just revs up like a manual tranny that has a slipping clutch shut off the car and restart and it goes away .
Team Owner
Did you check the vacuum line to the modulator? Is the bowden cable correctly adjusted? How many miles are on the car?
I have a symptom very similar to this that only manifests itself on the few occasions I have had it past 140 or so. When I slow back down to a full stop and get going again it wont shift out of first. Then all I have to do is pull it over turn the car off and back on and it's fine again. Never happens except when coming back down from high speeds I shouldn't be at anyway but it still bothers me that it's there. I also dont have a kickdown switch and I'm at 79,000 mi. I'll do a search on these vacuum modulator/ bowden cable thingies and see if I can figure them out before I ask you to explain them.
Thats cool im not real good with working on cars and i was looking for some help i was told this was the place to go for help please bare with me if i am asking dumb questions .
Thanks 1bgdog
Thanks 1bgdog
Team Owner
I know its sometimes easier to just ask a question in the hopes that another person with more experience will pipe up.
What i found is that if i take some initiative and do a bit of research, I find that I am more informed when the correct answers do show up.
My suggestion is to use the search function first , this will give you more foundation information, and then you will have a better understanding of the solution
