What are the Largest wheels and tires for an '82?
Just for a lark, I'm contemplating changing wheel and tire size. What are the largest wheels and widest tires that will, without modification, fit my 1982 US/AT?
Administrator - "Tyson"
As long as the offset is correct you could run 20's.
Realistically the best wheels for the money are 997 18's & 19's. They fit without any modificatons on any 928.
Quite a few 928's are wearing these (I have a set on my 81):
http://cgi.ebay.com/ebaymotors/18-Wh...spagenameZWDVW
Or 19's (these are non OEM):
http://cgi.ebay.com/ebaymotors/19-8-...spagenameZWDVW
8" backspacing on 9.5 fronts and 11 rears, can fit 275s up front and 295s in the rear. 305s in the rear with some fender rolling and maybe a 1/8" spacer.
mk
mk
these pictures of mine should say it all---no really, these are the largest you can go without serious fender mods:
19 x 8 et 67mm front
19 x 11 et 67 mm rear
997 Carrera and Carrera S with those sizes.
an 18 x 10 will work on the front, but you may have to do some fender work.
a 19 x 10 won't work because of offsets (in a factory Porsche wheel). You'll need to go aftermarket to use this size up front......
see picture below:
--Russ
see picture below:
--Russ
36's Baybee!!! Trow sum hi-jackers udder dare an git er up in da clowdz. Itz da tang, yu feelin me? Ah mean lock itz da onlay ting day be rollin down in El Ay. Yu Deeg?
No one has chimed in about Andrew's
===> 928 Wheel Fitment Calculator <=== ?
I haven't studied it, but it looks pretty good.
And our Australian mates have also done some pretty cool wheel/"tyre" write ups: http://www.landsharkoz.com/tt/ttwheels.htm
Supercharged
I'd like to get my calculator to work better with the pre-S4 body style. On the rears, are you running any kind of spacer? Also what brand and aspect tire are you running?
