Nitrogen?
Nitrogen?
When I had my last set of tyres fitted I was offered a Nitrogen fill. Free, wow!
'No thanks' I said, I'll stick with the regular stuff. (Same price too). Privately I thought "this is nonsense, just a sales gimmick to get me hooked on Go-Faster Nitrogen"
Now, I know that race cars use Nitrogen and it has advantages of cooling amongst others but unless one is interested in the last ounce of performance is there ANY advantage in Nitrogen on a road car. Methinks not. After all, air is already 80% Nitrogen.
Insight anybody?
Colin. 89GT.
Insight anybody?
Colin. 89GT.
OK guys
I buy the advantage of dry gas but any air compressor could be equipped with a dryer/vapour trap and achieve the same. If Nitrogen isn't just a gimmick there has to be more to it.
I'd like to lose 1000lbs of weight with Helium too George. But it's expensive and has a nasty habit of sneaking it's molecules through the tiniest of gaps.
Colin. 89GT
Colin. 89GT
Nitrogen
Bottled nitrogen has a maximum of 6 ppm (parts per million) water vapor.
Chronic Tool Dropper
MOst compressors are equipped with water traps, but they only remove droplets that are entrained in the air flow. Vapor goes right through. To get the air as dry as the nitrogen, you need at least a dessicant-type drier, and prefereably a regenerating type.
The differences between dry and not-so-dry air won't be noticed at all in normal street driving unless you check your tires with a gauge. On a race car, where you are fine-tuning the suspension with a pound or two of air, it will be more noticeable. Race tires tend to run a bit hotter than street tires anyway, so the effects of moisture in the air would be greater. No matter what "dry" gas you choose to use in the tires, it will take several fill/purge cycles to get residual moisture out of the tire, and even then it won't be moisture-free by any stretch.
On the helium idea, good deal if you can get it to stay inside the tire. Like a giant latex balloon, tires are not quite airtight enough to hold helium for any length of time. Helium is a pretty small molecule and manages to find its way through places where air can't quite squeeze through.
Captain Obvious
Super User
Super User
I think "change" is probably next appropriate word here, but after "delta". Too much Catholic education, then too much process engineering, then too much...
Air, as most of use know it anyway, is about 78% nitrogen. Maybe if the other molecules leak out, they'll leave just the N2 atoms in there. We really just need to get the water and water vapor out. The pure gases all pretty much subscribe to that pv=nrt idea.
For those who offered the "If it's free, go for it" suggestion. Well you're right of course. Nothing lost that way, but it was only the FIRST fill that was free. Thereafter if I needed to top up I'd have had to pay (and drive miles to a Nitrogen vendor too.) Now to me THAT's a no-brainer.
I stand by my original equation. N2 = BS
Colin. 89GT
Colin. 89GT
you have got to be kidding
I use NOS to fill my tires. its better than air, as i do have the advantages of it being dry, but im not concerned with the pressure rise as i know what pressures to set to before a track session to get to the correct pressure due to heat. the nitrogen will give less of a pressure rise spread due to it being dry and being without the water vapor. however to really use it you need to fill the tires at least 3 full times to get near 90% pure nitrogen in the tires.
at 30psi, its only 2 atm over an empty tire. so, you still have the volume in an empty tire to deal with. anyway, the weight of a 2 atmospheres greater in a tire is measured in near ounces, so using helium wouldnt save that much.
Mk
so,
Mk
so,
