Porsche cleans out warehouse #2
The Parts Whisperer
Here's some more:
92831501301 1 PWR.STR.RESERVOIR 36.47
9286134310170B 6 ROSE 5.74
92811126000 2 EXHAUST BRACKET 16.18
92810461118 2 VALVE SEAT 16.03
92835193600 10 RETAINING PIN 3.11
92851240902 7 HATCH HINGE BASE 4.21
92835506104 1 BRAKE LINE 28.06
92810461117 1 VALVE SEAT 27.52
92833124000 1 SPEED SENSOR BRACKET 27.5
92810461115 1 VALVE SEAT 27.35
92810119700 3 SPACER 8.75
92850431802 1 WHEEL WELL COVER 26.03
92853757302 6 THREADED SLEEVE 4.29
92800610113 1 STICKER 25.44
92800611900 1 STICKER 25.44
92830229811 1 TRANS.SHIM .15MM 25.27
92861217201 1 SHIFT LIGHT WIRING 25.09
92835282300 2 GUIDEPLATE USE KIT 9 12.39
92811035900 3 FUEL PUMP HOSE 8.23
92850525302 1 REAR BUMPER REINF. 24.44
92851241703 1 HATCH HINGE BASE 23.67
92811321502 2 EXHAUST BRACKET 11.17
92833352208 1 SUSP.SPRING SEAT 21.19
92850511202 5 BUMPER SECURING PLATE 4.1
92857425902 1 GASKET 18.97
92842440501 1 GUIDE TUBE 18.95
92863147100 1 THIRD BRAKE REFLECTR 18.87
92810771301 1 PIPE 17.33
92850533300 2 SPOILER SUPPORT 8.52
92842314100 3 BRACKET 5.37
92830331300 15 PAPER GASKET 1.06
92862823302 1 WIPER ARM LEVER 15.71
92857413302 1 CELL RUBBER GASKET 15.12
92820124902 1 FUEL TANK BASE 15.02
92830323121 1 TRANS.DETENT 13.92
92861247700 1 COVER 13.45
92862823000 2 RETAINING PLATE 6.71
92811317302 1 ENGINE LIFT BRACKET 12.73
92857334502 1 RADIATOR SUPPORT 12.62
92842404500 2 CABLE SUPPORT 6.19
92851241307 4 GASKET 2.73
92851226202 1 HATCH WATER DEFLECTOR 10.9
92860313504 1 CELL. RUBBER SEAL 10.6
92853715702 2 DOOR HANDLE PLATE 5.23
92842335706 1 PEDAL SPRING 9.17
92835504900 1 BRAKE LINE 8.82
92851217902 1 HATCH LOCK BASE-1MM 8.28
92811022303 1 LINE FITTING 7.97
92857329902 1 FOAM RUBBER COVER 7.82
92811035100 7 HOSE SLEEVE 1.02
92862431201 1 CONSOLE SENSOR TUBE 7.04
92863144800 1 RUBBER GASKET 6.95
92811054301 1 IDLE STABIL.BRACKET 6.92
92830229006 1 TRANS.SHIM 1.60MM 6.77
92855939703 1 ADHESIVE TAPE 6.73
92855939803 1 ADHESIVE TAPE 6.73
92800610207 1 DECAL-EMISSIONS 6.69
92830229003 1 TRANS.SHIM 1.00MM 6.32
92830229004 1 TRANS.SHIM 1.20MM 6.32
92861203701 1 REAR LID WIRING 6.24
92853762402 1 COVER,INTERIOR DOOR 6.24
92855561502 4 PLASTIC SPACER 1.42
92857334702 5 SPACER 1.13
92830229000 1 TRANS.SHIM .85MM 5.59
92830229002 1 TRANS.SHIM .95MM 5.59
92811056601 1 MANIFOLD GASKET 5.46
92853762502 1 CONTACT 5.38
9285051420001C 1 REAR BUMPER CAP 4.91
92855239502 1 DASHBOARD BRACKET 4.8
92842357901 1 SPRING GUIDE SLEEVE 4.76
92834765902 1 COLUMN SEAL RING 4.66
92862818501 1 HOSE CLAMP 4.17
92851141902 1 HOOD ADJ.PLATE 4.12
92870114103 1 DECAL - A/C 4.04
92850434302 1 RUBBER SLEEVE 3.99
92810717902 1 PISTON 3.73
92853755702 2 DOOR HANDLE PIN 1.84
92863120303 1 HEADLIGHT ADJ.ROD 3.44
92830330901 1 SPRING 2.85
92855119902 1 TOOL PANEL CAP 2.83
92810118900 1 OIL PAN SLEEVE 2.63
92830228301 1 O-RING 2.4
92830323524 1 TRANS.SPRING 2.16
92880315702 1 WASHER 1.13
92851261302 1 RUBBER BASE 1.09
92860913901 1 PLASTIC CLIP 1.04
92860913903 1 PLASTIC CLIP 0.89
i'll take the wheel well cover if it fits S4's and later ( i imagine they are all the same)
i assume its the spare cover in that honeycomb plastic with the foam lining on the bottom?
Basic Sponsor
Hi Mark,
I would like the following please :-
928 006 10113 & 928 006 119 00
Thanks,
Roger
Thanks,
Roger
The Parts Whisperer
The Parts Whisperer
Originally Posted by ROG100
Hi Mark,
Thanks,
Roger
Thanks,
Roger
