Number of ROW and Japanise cars in US and Canada
Some time ago I did Visual Basic code which went through all US model 928 VIN's and searched if Carfax website has records for them. Results are in this thread:
https://rennlist.com/forums/928-forum/311463-looking-up-all-the-928-by-vin.html#post4016599
Week or two ago infamous Danglerb mentioned at Pelican forum that he had checked some ROW VIN's from Carfax and it actually had data for them. Yes, I do read Pelican mainly to see if Herr-Kuhn has something interesting to say. Anyway, it was easy to change VB code and have it do similar check for all '81-95 ROW and Japanise VIN's too.
Code did run little over a week non stop and went through 37000 VIN's. As before it checked all the VIN's mentioned in Jörg Austen's book + 100 more and then some for few years. Results are fairly interesting. Who would have quessed there are 1300 non US models to which Carfax has records for and 10 of them are GTS meaning 6 previously unknown cases. As I do not have access to actual Carfax records I can't say how many of the cars are in US and how many in Canada. Though its fairly obvious 99% of Japanise models must be in Canada and ROW's mostly in US.
(1 Austen says 0001-0060 VIN's are reserved for prototypes and special cars. Based on this 0061 and 9561 are listed as first VIN for all years.
(2 Same as US '81 MY, there are several lower VIN's for both 4.5L and S models in Carfax than 0061. First listed US VIN is 0011. I think it's safe to presume ROW cars follow this same system and their VIN's start from 0011 also.
Its important to remember that ROW 4.5L and S have their own VIN sequences. This means there are triplicate VIN's with same last 4 digits up to highest ROW 4.5L VIN (0011-0657) and dublicate VIN's for highest ROW S VIN (0658-1418). Above last ROW S, only single US set exists (1419-1668).
(3 Carfax do not have any Japanise VIN's for '81-84 model years even though Austen lists them. This either means there simply aren't any in Canada (unlikely), Carfax don't have data for them even though they exist in NA, they use some unknown VIN sequences or are included in ROW sequence.
There doesn't seem to be any '89-95 Japanise cars either. This could be due to fact that most ROW markets got standard catalytic converter engine at that time. Making it unnecessary for Japanise cars to have US model engines like they had had in most previous years.
(4 Based on first 0011 US VIN for '81 I would expect lonely Japanise S to be 9511 in reality.
(5 As 0056 has records I think its safe to assume '82 MY ROW follow same formula as US model same way as '81 does. This meaning 0051 is first VIN for both 4.5 L and S models.
Its important to remember that ROW 4.5L and S have their own VIN sequences. This means there are triplicate VIN's with same last 4 digits up to highest ROW 4.5L VIN (0051-0497) and dublicate VIN's for highest ROW S VIN (0498-1502). Above last ROW S, only single US set exists (1503-2701).
(6 Austen lists two Japanise VIN's only. This matches combined total 2087 he gives for US and Japan. Carfax has VIN range of 2085 US models.
(7 Austen VIN ranges for '85 MY are exact same as in '84 MY. Since '85 MY data do not match what Austen says as total number of produced cars I think his '85 VIN's are wrong while '84 are right. Because of this listed range 0061-2228 is counted from Austen's number of produced cars.
(8 Same as in (7 applies here too. Japanise expected range is based on total US+Japanise number he gives with US number remove based on how many US cars have data in Carfax.
(9 Both (7 and (8 upper limits are nicely above highest ROW VIN's on Carfax giving extra validation that calculations can be correct.
(10 Austen doesn't give VIN sequence for '86 Japanise models but Carfax has several records for 4 separate VIN's. US '86 MY cars are not help in here as there are less actual VIN's in Carfax than what Austen says were made. I think its safe to say at least VIN's 9561-9643 exist. This meaning minimum of 82 Japanise models were made in '86 MY. If there are missing from total production numbers listed in few earlier threads its impossible to say with any certainty. It might be that total 928 production numbers are missing several 100 cars because of these (2, (5 and (10 early VIN's. Would need to do some calculations.
(11 Samuel's Club Sport site lists 2014 as VIN for ex Derek Bell CS prototype. Both Austen and Carfax say highest '87 VIN is smaller than that. This is interesting. Is Austen's upper limit 1914 wrong or did '87 CS protos use different VIN sequence than normal S4? 2011-2014 perhaps?
(12 None of the '88 Club Sports are in Carfax. While searching for them code also tried to find once again two US Club Sports but didn't turn up anything.
(13 Austen says ROW '89 S4/CS change to S4/GT happened in VIN's 1584-1585.
(14 Based on (13 there can be between 0 and 9 '89 GT's in NA depending on what 9 1585+ VIN's are, S4 or GT.
(15 Who has very late ROW in US or Canada? 0453 could be later car than famous green US model 0137 depending on when last ROW cars were made.
Code:
YEAR MARKET MODEL AUSTEN VINs CARFAX VINs QTY ------------------------------------------------------------------ 1981 ROW 928 0061-0657 (1 0031-0649 (2 72 928 S 0061-1418 (1 0018-1409 (2 134 Japan 928 9561-9617 - 0 (3 928 S 9561 (4 - 0 (3 1982 ROW 928 0061-0497 (1 0056-0491 (5 32 928 S 0061-1502 (1 0061-1482 135 Japan 928 9561-9660 (1 - 0 (3 1983 ROW 928 S 0061-1972 0073-1961 209 Japan 928 S 9501-9502 (6 - 0 (3 1984 ROW 928 S 0061-2088 0064-2076 270 Japan 928 S 9601-9620 - 0 (3 1985 ROW 928 S 0061-2228 (7 0061-2172 (9 315 Japan 928 S 9561-9633 (8 9571-9617 (9 4 1986 ROW 928 S 0061-1971 0103-1950 42 Japan 928 S (10 9603-9643 4 1987 ROW 928 S4 0061-1911 (11 0241-1687 (11 8 Japan 928 S4 9561-9746 9592-9694 8 1988 ROW 928 S4/SE 0061-2287 0104-1521 8 928 CS 5061-5070 - 0 (12 Japan 928 S4 9561-9827 9583-9798 13 1989 ROW 928 S4/CS 0061-1584 (13 0128-1555 11 ROW 928 S4/GT 1585-2488 1636-2284 9 (14 1990 ROW 928 S4/GT 0061-2652 0095-2595 13 1991 ROW 928 S4/GT 0061-1710 0234-1507 3 1992 ROW 928 GTS 0061-1015 0118-970 3 1993 ROW 928 GTS 0061-0681 0148 1 1994 ROW 928 GTS 0061-0566 0178-0387 2 1995 ROW 928 GTS 0061-0459 0128-0453 (15 4 ------------------------------------------------------------------ TOTAL 1300
Fascinating research and results, Erkka!
You are THE professor of 928ology.
The first thing that jumped out at me from your latest find is the highest quantites - 1984 and 1985 show 270 and 315 ROW, the tasty LH Euros with their modestly under-reported power levels.
And then the next year, 1986, there were a mere 42 ROW as the grey market faded away under the 32-valve onslaught from American Porsche dealerships. I wonder if any of those had the 86.5's proto-S4 underpinings?
And at the end of the day however, how many VINs were typo errors at the title offices during the grey-market's often-shady "federalizing" process, how many were stolen and VIN-swapped with crashed cars, how many were never titled and now lay rotting in some far-away collector's palatial garage? That's where I would look for the GTS's...
Inventor
Thanks Porken. Now I have even more reason to endanger the poor bank account if I find one.
I seem to recall reading here long ago that in 1986, 16(?) ROW 928s were possibly fitted with US-spec 32-valve pipe-organ-intake motors. Can anyone verify?
All 1911 made '86 MY ROW's, 16V and 32V, have S4 brakes, suspension and rear lift points in body.
That's very cool! Based on my WAG on numbers from what I see in the market, I was expecting way more '83s, and way fewer '85s. Guess folks with the best one's are hanging on to 'em!
Captain Obvious
Super User
Super User
From what I know, the 32V engine was an option everywhere but becasue it had less HP and had catalytics it wasn't a very popular option for buyers to get.
Originally Posted by DANdeMAN
My 1984 VIN finish with 2068...do I have a ROW car!?
And what does that mean.....
Code:
WP0ZZZ92ZES842068 = ROW with no records in Carfax WP0JB0924ES862068 = US with 6 records in Carfax
Just for info to Pelican people. Its impossible to check '80 MY from Carfax as '80 MY cars have 10 chars long chassis number. 17 long VIN was taken into use at beginning of '81 MY in late summer 1980.
'81 and '82 MY ROW 4.5L and S are easy to tell apart with VIN as is '80 also by the way.
Code:
WP0ZZZ92ZBS800011 = '81 ROW 4.5L WP0JA0929BS820011 = '81 US 4.5L window plate and door sticker WP0ZZZ92ZBS820011 = '81 US 4.5L fender stamping WP0ZZZ92ZBS840011 = '81 ROW S WP0ZZZ92ZCS800051 = '82 ROW 4.5L WP0JA0928CS820051 = '82 US 4.5L window plate and door sticker WP0ZZZ92ZCS820051 = '82 US 4.5L fender stamping WP0ZZZ92ZCS840051 = '82 ROW S
Originally Posted by michael j wright
Mine is a My 82 #000056!! So according to what I 've read in the info, mine should be some sort of special production car?
