HAPPY 21ST BIRTHDAY TO ALL 86.5's!!!
Are the later VIN 86.5 cars that have earlier build dates AUTOMATICS?
my 1611 is 5 sp and is 06 86
Just trying to make some sense of this.
Sorry for the double post.
Shark Slayer
Location: 'BETWEEN NORTH STAR BOROUGH...& THE CONCH REPUBLIC'
1 Post
SOMETHING'S FISHY HERE . . .
Back from computer melt-down... I swear it's from all the dang rain in Tex-A$$ lately..
OK -- RSKY BIZ's date is 01-86... VIN is 1639... (auto)
That means tonight and tomorrow night are her LAST nights to be 21!!!
We got some 'catching up to do'...
But wait... 86.5, built the BEGINNING of 86?
'Splain me, please!
'Splain me, please!
Good call James. They must have set aside a block of vin's for auto and manual cars, that would explain some cars with higher numbers built before cars with lower numbers.
Shark Slayer
1 Post
Originally Posted by James-man
VIN 1611 date is 06 86
Happy Birthday Indeed!
Is yours an 86? A or M? Our #s don't jive...RSKY BIZ is 1639 in 01-86...
Your earlier # is dated after mine. . .
Thanks!
WHAT have I started here???
Kim
'Splain me, please!
Now with regards to our whacky vins and build dates I have concerns about a company that is supposed to have great engineering that can't keep numbers straight. The underratted HP problem may be another symptom of bad Porsche math?
I am just kidding. Happy B!
James-Man,
Thanks!
Kim
Thanks!
Kim
MY cut of point between S3.5 and S4 was in July-August '86. Usually very few cars are made in July as it is vacation month for production line workers and also line is many times repaired and modified between MY's.
Shark Slayer
1 Post
Erkka,
I was hoping you would jump in, with all your previous VIN research!
So far all the numbers and dates coincide (in that they both ascend in order) except for James-Man's and mine.
His is a manual; mine an auto.
Does that jive with what your #'s show?
Thanks!
Confused... and soggy...in the rain...in the plains...yeah...
Kim
Thanks!
Kim
All auto companies have a summer shutdown, usually in the first two weeks of July. They then use that time to re tool for the next model year. anything after that time is the next model year.
They might have made some production planning like if there were more ROW engines on stock for whatever reason in one day they did mostly ROW cars then and did more US models next day when S3 engine supply picked up again. Also they tried to make several cars with same paint color one after another as every color change meant some downtime on paint area. Only now specialised manufacturers like Valmet Automotive in Uusikaupunki who make most of the Boxster's and Cayman's have paint lines whick are easily capable to make color change for each body without causing delay.
If there were serious bottlenecks in parts production like manual gearboxes it would have simply meant factory did more automatics which all have next higher numeric VIN's without leaving any empty spaces for manual car to be made later. Since Porsche do not give anyone any promises that car will have certain VIN it doesn't matter what number they asing at production line to which car. All that matters is that customer gets car with correct color and options. If something like S3 engine parts were on short supply one time or another this would only show up in small number of US cars produced for this month. Not in jumps in VIN/build date combinations. This doesn't make sense as Porsche would not have gained anything by doing it.
In any case it would be great if Chuck's side had build month also listed. It would give more info if odd cases mentioned here are common or not. Total '86 US production was 2887 cars. Out of those VIN's 0061-0937 were S3 and 1001-3010 S3.5. This is approximately 262 cars each month. If they were done evenly over normal 11 months MY production cycle, cut of points would be something like this:
Code:
08/84 0061-0324 09/85 0325-0587 10/85 0588-0851 11/85 0852-0937, 1001-1178 12/85 1179-1442 1396, 1459 01/86 1443-1705 1639 02/86 1706-1969 1955 03/86 1970-2233 04/86 2234-2496 05/86 2497-2760 06/86 2761-3010 1611 07/86 2899
1611's build month simply do not make sense based on what I know about 928 production. I'm not saying its wrong but there must be interesting explanation if its right.
As numbers show, S3.5 is really artificial name. Later S4 suspension cars outnumber earlier cars more than 2:1. So it should be S3.3 or maybe '85/10 or '85/11 based on month when suspension change happened. .5 is easy name to remember so S3.5 they will be forever probably.
Hi - my '86.5 is #2899 (moss green metallic with A/T) with a build date of 07/86 according to the door jamb label. Maybe I should find out from Porsche the actual build date?
Adam
Adam
Shark Slayer
1 Post
OK, Shane...
You shared yours. . . I'll share mine -
RSKY BIZ:
(sorry 'bout the {lack of} quality)...
Erkka,
You really are a wealth of information in this regard. I'm sure there are 'stories'... lots of stories...if we tried to uncover some of this...
Thanks...perhaps others will jump in and elucidate further...
Kim
RSKY BIZ:
Erkka,
Kim
