928 Forum 1978-1995
Sponsored by: 928 Specialists
My Flexplate - Crank Endplay Check Pictorial
Old 05-16-2009, 10:11 AM
  #106
Larry Velk
Larry Velk's Avatar
Regarding surface finish of the thrust face - Jaguar 6 cyl. are reported to have thrust surface issues when overly stiff racing clutches are used. The fix is first don't use a pressure plate with too much spring pressure, secondly they make a huge deal out of making the thrust face super smooth and 90 degrees and state you must have a machinist who can do this. Maybe not relavant on 928's as when you get thrust failure you can't rebuild (usually) anyway.
Old 05-07-2010, 09:30 AM
  #107
auzivision
auzivision's Avatar
Default Dial Indicator Tool Holder
I want to make some crank end play measurements and couldn't get anything repeatable using micrometers.
I have a dial indicator which I haven't used for any more than checking tread depth.
What is the tool call that allows you to mount the dial indicator with full 3D adjustment as seen here?
I'd like to have one of these.
Old 05-07-2010, 09:51 AM
  #108
ROG100
Basic Sponsor
ROG100's Avatar
Dial Indicator Magnetic Base - Harbor Freight for about $25.
Old 05-07-2010, 09:59 AM
  #109
auzivision
auzivision's Avatar
Thanks Roger, found it for only $10.
I can almost see Harbor Freight from my office... it's literally that close.
http://www.harborfreight.com/hand-to...ment-5645.html
Old 05-07-2010, 10:18 AM
  #110
blown 87
Rest in Peace
blown 87's Avatar
I never could get a mag base to work there, not solid enough.
The VW tool (Base) for setting the cams works very well.
Old 05-07-2010, 02:01 PM
  #111
Leon Speed
Leon Speed's Avatar
Luck would have it that the rod that screws into the magnetic base fits exactly into the bolt holes for the bell housing cover, at least in the base that I bought on Ebay. I do have an X-pipe, so I'm not sure of there's enough clearance with an normal exhaust.
Old 05-07-2010, 02:06 PM
  #112
blown 87
Rest in Peace
blown 87's Avatar
That would work out well.
Old 10-13-2013, 09:08 AM
  #113
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,251 Likes on 1,245 Posts
I think that original DIY post from both Mr Harkin and Mr Ball should also be updated for those dont read this whole thread. to include..
FWIW if you dont check the rear pinch bolt then you have not completed this inspection/repair.
Most of the cars I have checked have loose rear pinch bolts,
so its safe to assume that these rear pinch bolts have never been retorqued.
If the rear bolt is loose then this can cause the drive shaft to migrate and preload the thrust bearing,
so just releasing the front flexplate isnt a cure for this issue.
This to make sure that the rear pinch bolt is also removed and inspected then installed.
NOTE the other issues with a loose rear bolt is that the shaft can migrate so far forward that the rear bolt will begin chafing on the side of the shaft cutout,
thus damaging the bolt shank and weakening it,
NOTE if a bolt is found with this damage then it should be replaced and the shaft moved rearwards before the new bolt is fitted.
NOTE torque to 66 ft/lb add a drop of blue loctite to the bolt threads
Old 03-22-2019, 11:12 PM
  #114
frugal928
frugal928's Avatar
I followed Bill's procedure and I was in tolerance.
Flexplate preload released: 2 mm (6.65mm) before & (4.65mm) after.
Crank endplay: 0.006 in (0.15mm) .
I was really smiling because the PO don't check it. However he always ran Hi zinc content in his oil 1600 ppm. 15W50 oil for a long time. I'm waiting on the Ritech Clamp from Roger.
Old 03-23-2019, 12:06 AM
  #115
Mrmerlin
Team Owner
Mrmerlin's Avatar
Frugal was the rear pinch bolt loose?
To tell set the torque wrench to 66 ft/lbs and loosen it see how much force is used to remove the bolt.
Then verify the shaft is centered in the input shaft of the transaxle.
Old 03-23-2019, 08:38 AM
  #116
Geza
Geza's Avatar
When checking mine, I set the wrench to 66 lb-ft and tried to tighten. It started to move, so I knew it was not up to torque. Then I removed and examined (centered and no marks) and reinstalled/torqued. This is after 128K miles, as I'm sure this was never checked in the past.
It may be self evident, but the heat shields just need to be swung out of the way, not removed entirely.
Old 03-23-2019, 08:40 AM
  #117
awilli6
awilli6's Avatar
What are the signs of TBF?
Old 03-23-2019, 10:20 AM
  #118
FredR
FredR's Avatar
Excessive crank end float, metal particles in the oil and can also include a seized crank. The owner usually has no clue that something is amiss until something drastic like seizure occurs.
Old 03-23-2019, 04:03 PM
  #119
Constantine
Constantine's Avatar
What Fred said and:
Hard start or no start after engine is run up to temperature and then turned off.
Deep knocking sounds from the engine when idling.
Oil pressure fluctuations when driving.
Old 03-25-2019, 02:08 PM
  #120
Wisconsin Joe
Wisconsin Joe's Avatar
Tears.
Anguished screams.
Rending of garments.
Emptying of wallet.
The problem is that there's virtually no symptoms until it's too late.
Which is why checking the flex plate on a regular basis is essential.
Quick Reply: My Flexplate - Crank Endplay Check Pictorial
