Quality of idle
Originally Posted by John Speake
As well as borrowing a tester from a kind soul, you would also need to fit the later EPROMS in your LH and EZK ECUs for diagnostics. Your 87 cars don't have diagnostic chips, but the car is already wired with a diagnostic 12 way port, like the MY88.
I'll now expose more of my native ignorance: are the EPROMS you're referring to different from the Autothority chips that it currently has? I'm assuming so.
Rod
Ah ! OK, I understand that the AA chips were based on an 88 S4 EPROM, so you should be OK.
Rod
Bear in mind that you require the tester to have the earlier type of lead that car a 12way rectangular plug, not the later round 19 pin type.
My "Spanner" is available with both types, and I am sure someone on Rennlist has a tester and 12way plug lead.
Under the Lift
Rod:
You can borrow my JDS Spanner. I would have run it on that car before Brian and I sent it off had I known it had the updated EPROM.
Send me a PM with your address.
