928 Forum 1978-1995
Sponsored by: 928 Specialists
My stick leans left
Old 05-01-2007, 07:41 PM
rcoble
rcoble's Avatar
Default My stick leans left
My stick shift is too far left (5 speed). 1st and reverse are all the way against the left edge of the opening, and 4th/5th are in the middle of the opening. As I am doing some clutch work soon I would like to get this centered while I’m under there, so the shift boot will stay on, and all will look right. Where / which / what do I need to uncouple and re-couple in the correct spot. or??
Robert
Old 05-01-2007, 07:47 PM
Edgy01
Poseur
Edgy01's Avatar
Has the vehicle ever been in an accident?
Old 05-01-2007, 07:48 PM
Jim bailey - 928 International
Jim bailey - 928 International's Avatar
the stick adjustments are made in the rear. The shift linkage rod to coupler will slip in and out or slide side to side. Loosen the bolt and move the rod as needed.
Old 05-01-2007, 07:55 PM
rcoble
rcoble's Avatar
Thank you Jim. My assumption was that all but one connection would be keyed and un-adjustable.
Old 05-01-2007, 08:03 PM
The forward shift linkage rod also has fore and aft adjustment BUT it is not easy to do at all. Focus on the rear coupler also inspect the plastic bushings for wear they are slightly slotted front to rear but there should be no radial play. When the bushings perish you get very sloppy shifting.
Old 05-01-2007, 08:32 PM
Ed Hughes
Ed Hughes's Avatar
You may want to mark the coupler position even though it's not where you want it. That way you've got a baseline and a starting point to go back to, should you do something goofy.
Old 05-01-2007, 09:22 PM
Shark Attack
Shark Attack's Avatar
actually I just had to do this. If you losen the clamp just a tad that it still has friction, you can get back in the car and with a tiny bit of force move the shifter in to the position you want and becasue the bolt is only slightly loose, the shifter will stay there while you tighten it back up.
Old 05-01-2007, 09:58 PM
rcoble
rcoble's Avatar
Thats the info I needed, thanks all.
I'm a little dissapointed my thread title didn't generate a lot of wisecracks.
Old 05-01-2007, 10:07 PM
animal8526
animal8526's Avatar
just a thought... my stick is to the left also, but the gates all appear normal. its as if there were two centering springs, and one is missing. I get all resistance when pushing the stick right, all assistance when pushing it left... is this related?
Old 05-01-2007, 10:14 PM
FlyingDog
FlyingDog's Avatar
Nope, broken or missing springs in the gearbox.
Old 05-01-2007, 10:23 PM
Randy Carter
Randy Carter's Avatar
Jim Bailey , 928 International
OMG! I thought he was being funny. That ****e means something mechanically? Nah, ya'll are pullin' my stick. This thread belongs in Off Topic. Little Randy will move it any moment now.
Robert, you shouldn't complain. At least you have enough stick to lean!
There, feel better?
Old 05-01-2007, 10:28 PM
animal8526
animal8526's Avatar
shucks. thats what I thought... I do need to rebuild the box or have it rebuilt anyways.
Old 05-01-2007, 11:22 PM
Andre Hedrick
Rest in Peace
Andre Hedrick's Avatar
Please check with your Tailor, and the phrase is "Dress Left"
Old 05-01-2007, 11:52 PM
Shark Attack
their is no laughing in this forum unless the great admin makes the joke.. we take 928's very serious here
Old 05-02-2007, 02:18 AM
jpitman2
jpitman2's Avatar
99% of the male population dress to left dont they?
jp
Quick Reply: My stick leans left
