My fuel light went on!
One more thing I thought I had to fix but is really just fine...
After driving it since August and running the take low quite a few times and never seeing the low fuel light (except when starting the car) I had decided that something on the sender was bad.
Last night I was driving home and I thought I was really pushing it to the edge when all of the sudden the light came on! 3 miles later (today) I filled up the tank and put in 19.393 gallons. Reading other messages here about low fuel/fuel capacity tells me I probably have another 2-3 gallons to go.
I also read something about calibration... how do you do that? I'd like the needle to point to reasonable places when the tank is full and low. Can I calibrate the light too?
What year is your 928? The digital dash has a feature to calibrate. It is all documented in the diagnostic manual of the dash.
Theo
http://jenniskens.livedsl.nl
http://928gts.no-ip.info
Theo
There is no calibration per se, but if you feel adventurous and electronically talented it's certainly possible to tweak this -- you could also change where the fuel light comes on by moving the contacts, but then you would have to shorten the wires(or lengthen them, if you want a reduced margin).
First clean all contacts between the sender and the gauge, and clean the wires. If you're lucky, like I was, that will improve it enough that you won't think it worth the hassle to go from 95% perfect to perfect.
Theo
Theo
Sorry for the thread drift, Bronto, I just had to get that out.
Hi Chaad,
Thanks for your comment! I appreciate that. I had to change ISP a few times and my website was therefore hard to find. Sorry about that.
Bronto: for the '79 you will have to stick with Sharkskin. He said it all. There's a few instructions around when you want to dismantle the in-tank sender.
Theo (1992 928 GTS midnight blue)
