Transaxle codes, how to ID?
I was looking at a transaxle the other day, wrote down the code and I am getting noplace decoding it. G28 11 1271 1F05121
if this number was stamped on the transmission & it had a 12 after the first 11 then it is an LSD
You wrote 1271 If it was 12 (space) 71 then it is probably an LSD (of course people do swap things in and out of the differential).
you also wrote 1F05121 but so far as I know there should be no letters only numbers
Marton
Marton
Code:
G28/11 12 11F05121 123456789ABCDEFGHI 1 = manual gearbox 23 = 928 56 = 11 is US '85-86 89 = 40% ZF LSD B = transmission for 8 cylinder car C = 5-speed D = model year, F = '85 EFGHI = serial number with transmission type and MY, first US box for '85 was 5001
