Can starter gear be replaced?
Looking at the starter gear on the starter of the '88 I just bought, and it looks more worn than I'm comfortable with. Can I replace just the starter gear...or do I have to buy a complete new starter? All's good except the engagement gear. Thanks.
Harvey
Harvey
Originally Posted by Imo000
How bad is it? Can you post a picture?
Harvey
IIRC those gears are tapered so the middle is higher than the ends. That's for easier engagement if the gear doesn't line up perfectly with the flywheel. I'd compare it to your other car, or to any new starter at a shop before buying a new one.
Jim Mayzurk
93 GTS 5-spd
Jim Mayzurk
93 GTS 5-spd
If it's all working, leave it alone until it fails. I suppose you can take it to a shop that rebuilds starters and other electric motors but since this one is almost 20 years old they're going to tell you to rebuild it anyway. Do you let them do it, or do you get one from the discount parts store that's guaranteed forever? But that leads us back to the first question. If the starter operates in its present capacity, why mess with it at all?
Harvey
Captain Obvious
Super User
Super User
If you want, I can take a picture of the starter that I took off the parts car. This way you can compare them and see if in fact the starter gear is worn or its jsut cut that way.
If that's not too much problem, I'd appreciate a foto. Then I'd know whether to start ordering parts or how to plan. My starter's gear wear looks un-natural to me. Not like any starter gear I've ever seen. JP Rodkey says that I can replace the starter gear. That sound good. Now to find one (I'm pretty sure I need one).
Thanks much!
Harvey
Thanks, ImoOOO,
Without a doubt, my starter gear is toast...yours looks like it should. Now, I have to figure out my next step. I really appreciate you doing that. No, my gear is worn on both sides to a thin piece of metal in the center.
I "owe" you.
Harvey
I "owe" you.
Harvey
Captain Obvious
Super User
Super User
How can a starter gear wear out so much?!?! I meany, how many times did it had to be engaded to wear out like that. Maybe it got stuck in the ON postion at some point and wore itself out.
How's the rind gear looking? Are the teeth realy worn too?
P.S. The starter in the picture is for sale, if interested send me a PM.
Inventor
Harv,
I've got a couple/three stock starters, one is rebuilt but 2 years used, one is a core. (I bought a pair of mini-starters.)
A spacer brtween the starter & the bell housing was missing, causing the starter to not be lined up good. I also hope the ring gear is fine but I'm not going to tear into it until I get a clean title back in my name. It got delayed for several resons...one , I insisted that the mileage be posted on the title but they say the car is too old. I gave up as the bill of sale shows mileage anyway and I can get it notatized... Any day now I hope the title will be back and I'll start ordering parts.
Harvey
Harvey
