Timing Belt Wear Question UPDATED 2-4-07
#121
Under the Lift
Originally Posted by ROG100
Bill,
Heres a pic of the left hand cam gear with the TB in place.
Slightly off center but no where near the front as on the right side.
John Kelly's post with pics illuminates this as well. The rust inside the plastic bushing signifies a lot of corrosion that shouldn't be there. Perhaps poor sealing of the pivot bolt. Whatever the cause, rust is very abrasive.
#122
Basic Sponsor
To clarify my decision about upgrading to the later style bracket between the WP and Tensioner roller carrier.
To me this will greatly decrease the possibility of this situation happening again.
Does the group agree that this is a positive upgrade?
#123
HTML Code:
The center TB cover is different but can be changed to accept the extra bracket very easily.
Whoever (PO) put the new style WP pump in, they also modified the center TB cover.
I think they did it with a lumberjack axe; does not really matter as it is only cosmetic.
I will try to tidy it up when I put it all back together.
Marton
#124
HTML Code:
Marton
#125
Received 1,543 Likes
Is the tensioner carrier the same?
87 is 928 105 489 02 the one we have here is 928 105 489 0R (yes R )
PET shows 928 105 540 05 as the carrier part number for an 86.
Calling Mr. Bailey....
#126
928 Collector
Rog I went through this with my '85 Euro. The tensioner sits farther forward, so the tbelt cover in the centre must be replaced with an S4 one. You may have to mod the driver's cover shorter to fit it. The tensioner arm and tensioner must be upgraded as well. The new pump will spin against the old centre cover as well so double reasons to change it ALL.
#127
Basic Sponsor
Interesting - when I did this to my early 87 it was just a case of cutting away a small piece of the cover to accommodate the new bracket.
I would have thought that an 86.5 and an early 87 would be practically the same.
Calling Mr Bailey please!
#128
Roger, an 86.5 might in fact have a lot of S4 parts. Lord knows its true for the electrical bits.
Yo! Jim?!
Yo! Jim?!
#129
Basic Sponsor
According to PET the 86.5 and the early 87 had the same center cover.
As this mod worked on my early 87 my gut tells me it will be OK on the 86.5.
Oh Jim are you out there
#130
The attached pics illustrate in one case, the 'S4' carrier arm and stud array on the left used from '87 - '95 compared to the late 32v arm assembly as used through '86.5 with the pivot bolt .... on the right.
The second image shows the 7.4mm ( ~8mm) differential offset observed in the piston rod dimple of the arm for pivot bolt applications from mid run 16v motors through to end of the early non-S4 32v motors ( both have the tapped hole for the tensioner alarm, beginning ~'83). The arm on the right is the same in both pics - sort of a 'mid generation step.
The forward offset was to center the line of force acting on the TB so as to minimize any residual torque forcing the tensioner roller and carrier arm to twist sideways ..... causing the obvious mistracking.The major change was a thicker mounting flange for the tensioner body .... which brought everything 'in-line'.
The S4 pivot stud not only added more robust M10 threads into the pump body, but increased the span between the pivot bushings - further stabilizing the arm: the last evolution was the cross brace from the arm tip to the pump body.
The vertical plane through the center of the cam, crank, oil pump and water pump pulley drives was unchanged from '78 - '95: that is why it is a breeze to update easily.
#132
Basic Sponsor
Hi Garth,
Great info my friend and thanks for taking the time to post.
My carrier arm is the same as the one on the left in the top picture and the one on the right in the lower picture.
So I should be good to make the change - Yes?
#133
Hi Garth,
Before typing more, which change are you referring to? .....doing the S4 arm/pump/stud to replace the later gen pivot bolt type?
#134
Basic Sponsor
Hi Garth,
"doing the S4 arm/pump/stud to replace the later gen pivot bolt type?"
I did this on my early 87 which already had the later style WP.
Just added the bracket that goes from the pivot point to the WP.
Apart from the bracket the only other change was the slight mod to the center cover to accommodate the bracket.
I am assuming that I can do the same with the 86.5. Except in this case would have to use the later style WP and Pivot pin, the updated idler roller and screw that holds the bracket to the pivot point.
Am I making the right assumption or do I need a different roller arm?
#135
928 Collector
Start with 86.5
Update brace
needs pump update
ok
update pump
needs idler arm update
ok
update idler arm
needs updated tensioner
ok
update tensioner
needs centre cover update
ok
update centre cover
needs updated driver's cover
ok
update driver's cover
Simple isn't it
Update brace
needs pump update
ok
update pump
ok
update idler arm
ok
update tensioner
ok
update centre cover
ok
Simple isn't it
