928 Forum
Sponsored by: 928 Specialists
Timing Belt Wear Question UPDATED 2-4-07
Old 02-13-2007, 01:58 PM
  #166
sharkmeister85
User
sharkmeister85's Avatar
Maybe I didn't read closely enough, but was there ever a determination made about the cause of the belt wear on the smooth side? Or was it judged to be in the realm of normal? Sorry, I had to ask. I'm such a noob.
Glenn
sharkmeister85 is offline
Old 02-13-2007, 02:03 PM
  #167
ROG100
ROG100's Avatar
Glenn,
The belt wear still has a ? in my eyes but maybe it is normal.
It does come in contact with the idler roller and thats about all.
Roger
ROG100 is offline
Old 02-13-2007, 02:54 PM
  #168
SharkSkin
SharkSkin's Avatar
Originally Posted by ROG100
Glenn,
Roger
Water pump too...
SharkSkin is offline
Old 02-13-2007, 03:20 PM
  #169
heinrich
928 Collector
heinrich's Avatar
I guess in "H's" eyes I am a noob as well - I better be carefull what I say while he is looking at the thread.
H,
Not long until I find out about the alignment!
Sorry to offend, closed the thread.
heinrich is offline
Old 02-13-2007, 06:49 PM
  #170
H2
H2's Avatar
Originally Posted by docmirror
That type of clip is pretty generic. You should be able to get it at your local NAPA or even possibly a good hardware store. Ask for a 'snap ring' and take the shaft it fits with you. If you don't already have it, a compound snap ring plier is useful to remove and install.
Hope this post was useful, wouldn't want to be a noob with no clue.
User, uh, Doc
I know this isn't much of a contribution...but if you try to scrimp on a snap-ring plier set, you'll probably regret it when working on some 928 snap rings. I went through a couple of cheapie pliers before I realized that it takes a small AND VERY STRONG TIP for some snap rings. Bending and breaking tips was too common an occurance and can be very frustrating. This is where the Harbor Freight tool failed on me.
Harvey
H2 is offline
Old 02-13-2007, 07:14 PM
  #171
Garth S
Garth S's Avatar
Roger,
The two external snap rings are 24x1mm and 18x2mm for the idler roller and tensioner rollers respectively ....
Garth S is offline
Old 02-14-2007, 09:46 AM
  #172
ROG100
ROG100's Avatar
Garth,
The 18x2 could be difficult - I am still looking.
Roger
ROG100 is offline
Old 02-14-2007, 10:32 AM
  #173
ROG100
ROG100's Avatar
OK its the 24x1 that I am looking for - if anyone knows where I can get one let me know please.
Roger
ROG100 is offline
Old 02-14-2007, 11:18 AM
  #174
ROG100
ROG100's Avatar
Looking at the DIN standards for Metric Circlips (Snap Rings).
Shaft diameter is 25.2mm - Groove I/D is 24.5mm - Groove width is 1.5mm
DIN 471 External Metric shows the closest match
Shaft Diameter 25mm - Groove I/D is 23.9mm - Groove width is 1.3mm
Snap ring I/D 23.2mm x 1.2mm thick.
Part number = D1400-25
I need to track down one of these puppy's.
What suprises me is that if Porsche were to use a non standard snap ring then they would call out a Pt Number for it on PET - but no number exists.
ROG100 is offline
Old 02-14-2007, 11:36 AM
  #175
Chris
Chris's Avatar
Roger, are you looking for the snap ring which helps locate the large roller on the shaft? Just ordered one from 928specialists, I have the part number at home.
Apologies if this is not what you are looking for, this thread is long !
Chris
Chris is offline
Old 02-14-2007, 11:44 AM
  #176
ROG100
ROG100's Avatar
Went back and looked at PET as I could not believe Porsche would not have a number for the circlip.
If you are interested look at PET MY 88 illustration 103-10 and find item 47 on the list of parts.
Item 47 is not shown on the diagram. However it is a circlip with a Pt No N0122771 which is an update from Pt No 900 908 006 00
I just ordered one and we will see if it the right part.
Roger
ROG100 is offline
Old 02-14-2007, 11:52 AM
  #177
ROG100
ROG100's Avatar
Chris,
No it is the other one and I may have found the Part Number - see my last post.
Roger
ROG100 is offline
Old 02-14-2007, 12:17 PM
  #178
ROG100
ROG100's Avatar
Well I checked with the guru's - DR & Jim B - and drew a blank.
I guess I am on my own here!
ROG100 is offline
Old 02-14-2007, 01:43 PM
  #179
docmirror
Shameful Thread Killer
docmirror's Avatar
NAPA, try PN 1342, 1340 or 1047, 1045. 0.924" I know it's not metric, but looks to be close. Take your shaft with you.
Doc
docmirror is offline
Old 02-14-2007, 04:34 PM
  #180
marton
Super User
marton's Avatar
HTML Code:
myself, I never go anywhere without it,
Have my new TB installed but battery is flat
Tomorrow is the big day
Marton
marton is offline
Quick Reply: Timing Belt Wear Question UPDATED 2-4-07
Contact Us - About Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
