Timing Belt Wear Question UPDATED 2-4-07
#136
Basic Sponsor
The roller arm and new tensioner is the straw that broke the camels back.
#138
Basic Sponsor
I will recommend we stick with the original setup and do a visual/tension check every 12 months.
Thanks for all the wonderful advise.
#139
Received 1,542 Likes
PET shows the same tensioner part number for 85, 86 and 87 USA motors? 928 105 066 00.
so why is the tensioner different?
#140
The cover issue comes into play if the cross brace is added .... otherwise, no change.
I've thought of drilling & tapping the head of a pivot bolt and making a cross brace to the old style pump - just haven't bothered yet .... will do it first on some poor unsuspecting 928'er who wants a hand with a TB ...
#141
HTML Code:
new pump will spin against the old centre cover
Marton
#142
928 Collector
OK
For the '85 Euro I did this on, what I listed is correct but that is, granted, a 16V. The US 85/86 pumps have no boss for the little brace but I can't say for sure if that is on the S4 plane or not. I am pretty sure that the hole of the S4 arm (that you need Rog) and that of the 85/86 are different I/D's because the S4 bolt and the 85/86 boss are different O/D's. Garth can you confirm/deny?
So, Rog, I'm sorry, looks like you need an updated roller but NOT a tensioner, because the tensioner and arm are already in the same plane. Let's let Garth confirm. About the arm, we need to make sure the I/D of it is good for S4 pump.
#143
Originally Posted by heinrich
OK
From the better close up attached, the 'S4' set up on the left is compared to the early generation 32V ( and some of the last 16v).
All pivot studs and bolts are of the same 12mm diameter - and both use the same bushings in their respective arms: the stud has 38mm of working length for the bushings as compared to the 28mm distance of the bolt. With the latter, there is also the 6mm thickness of the underlying spacer .... plus the height of the water pump boss. The boss is absent on the S4 gen. pump. These features are combined to set the large tensioner roller in the vertical plane of the TB & drive components.
It is the presence or absence of the pump boss that dictates which carrier arm and idler roller to choose .... for the pumps are otherwise identical [ the last gen pumps have additional reinforcing ribs cast in as well as additional tapped holes for the cross brace - but are dimensionally identical].
Anyway, the pic says it better than I
The idler rollers are almost identical, but the S4 version shell has a #6905 bearing pressed in vs the # 6004 used for the early 32v.
#144
Garth? I don't suppose you have any images of the different water pumps? That would complete the picture.
#146
Originally Posted by Bill Ball
Garth has already pulled a lot of part rabbits out of his hat.
#147
Originally Posted by worf928
Surely Garth isn't out of Rabbits? Say it ain't so Garth
Hummm - I've got a S4 pump here, no 16V pump - but maybe some pics: Actually, I think Roger previously posted excellent pump pics back when a hacked uprebuilt pump would not allow the cross brace to fit.
#148
Interesting topic...good start for an article on "How To" update your early car's Idler Roller and Cam belt System to S4 standards....
I wonder if there's any market for an update kit?
Harvey
Harvey
#149
Basic Sponsor
Once all the parts are recieved I will post pictures and try to show everything side by side.
Last part to arrive is the roller carrier arm. Coming from Germany.
Roger
Roger
#150
Basic Sponsor
Attached is a list of the old & new part numbers showing what needs to be changed.
I just modified the file with an update on the idler roller number
