Warning(?)/Observation about Hüco Ignition Units
They don't play together, well!
(I broke my factory ignition amps) by trying to remove them. I was happy to find the Hücos (made in Germany), at a cheaper price. After installing them, however, my idle would sporatically drop, and stumble when putting into gear. I thought it might be the reference sensor, and ordered one, but being impatient, I bought some Bosch (made in USA) units, today. Here's what I observed: (2) Hücos = stumble, (1) of either Hüco + (1) Bosch = purring, (2) Bosch = purrring. I reckon there must be a ciruitry thing that makes two Hücos interfere with each other. https://members.rennlist.com/porken/IgnitionAmps.jpg Hüco (Hueco)# 13 8012 BTW, look around - you should be able to get Bosch units for ~$60/ea. Trivia: the Hücos have an aluminum base, the Bosch, steel. |
Is it possible one of them has a factory defect?
I suppose, but since both Huco units worked when combined with a Bosch, I doubt it.
Sounds like RFI.
Originally Posted by ZEUS+
Sounds like RFI.
Yep - shielding doesn't grow on trees. Some costs savings cost too much. |
It appears the problem was non-resistor Bosch plugs - W7DC, versus the factory WR7DC. The Hucos can't handle the RF.
(I put in some colder plugs with resistors.) WR6DC+, to go along with more cam and ignition advance. I reinstalled the Hucos, and the stumble did not return. I've got proper spares, now, I guess. :D |
