Start-up after TB Job Question
I changed my oil and got my clutch pressurized today. I checked all my fluids and all look good.
I went to start it, engine cranks, but either no spark or fuel. I haven't checked which yet.
My question is about warning lights. The central warning light is solid and a warning tone. Brake pressure, coolant and oil are good, so does this go out once the fluids have cycled?
Accompanying that, though, is rapidly flashing blinkers on the dash. The only reference I think I can find to this is if a flasher bulb is burnt out, but they all appear fine and hazards and left and right turn switches do as they're supposed to.
So, is this rapidly flashing blinker another start up warning? If so, what does it mean?
Thanks,
Matt
Thanks,
Matt
Originally Posted by blown 87
Are you sure it is in time?
Does it spin over faster than normal?
I'm not getting any combustion at all, no coughs.
Matt
Under the Lift
Did you refasten the coil wires, including grounds? On some MY, the ignition ground on the driver side is removed as part of the TB job.
Rest in Peace
It sounds like you need to find out what you are not getting.
If it spins over at the same rate you should have about the same amount of compression as before, so check for spark and fuel, as others above have suggested.
Under the Lift
I'm not going to mention starter fluid
So, yeah, pull a plug and see if you have spark or just check with an induction timing light on one of the plug wires on each side.
Rest in Peace
I am pretty sure I reconnected the ground on the driver side, but will double check. I have a timing light, so I'll check those while my wife cranks.
What I suspect, though, and what may be causing the flashing hazards is that I removed the alarm and set up a jumper. I am wondering if I need to revisit that. If the jumper is not correct, no spark, correct? I reinstalled the alarm, but it won't let me do anything without going off now.
No hurry on this, I will sort through it tomorrow or tonight.
Thanks, I will report again, and welcome any other ideas or thoughts on the alarm.
Matt
Craic Head
Matt,
What Bill said. I found that when I got done I had forgotten to put on BOTH ignition coil wires at the coils. I had surveyed everything, didn't see anything hanging loose and thought it was ready. As soon as I cranked it over a few times (and sweated profusely) I realised I had tucked them up under the fender lip to get them out of the way.
Check your owner's manual about the flashing lights. Is the car level? If the front end is still up I don't think the sender will see any oil and it won't let you start without it. (also if you filled it with the front end up you may have to drain some out when it's level).
Just saw your last post. The alarm is probably more likely than the stuff I said. Nevermind.
BTW- Do you have a different mixture setup for being at that altitude? Just curious.
Good luck, by Sunday you should be cruizin .
Under the Lift
Oh, the alarm. I can't keep straight if it kills spark, fuel or both. But if you fiddled with that, get it back together. It would be safer if it killed fuel or both rather than just spark, but I can't remember.
To disable it, I jumpered 15 to 87A, but now see reference to 30 to 87A and can't find Wally P.'s write up about it, which I would assume to be definitive. I will send Wally a note and maybe he can help.
I should have mentioned the alarm the first time.
Matt
Can't OVER emphasize!!! Check BOTH coil wires. My Buddy Chris burned his to a crisp due to one being disconnected. The unburned fuel from one cylinder bank collected in the cat & ignited- Just Doublecheck...
