NAPA oil filter OK?
Part Number: 51285
UPC Number: 765809512856
Principal Application: Porsche 928 (78-95)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 5.811
Outer Diameter Top: 2.967
Outer Diameter Bottom: Closed
Thread Size: 20X1.5 MM
By-Pass Valve Setting-PSI: 30
Burst Pressure-PSI: 285
Max Flow Rate: 9-11 GPM
Nominal Micro Rating: 32
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.740 2.370 0.275
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 5.811
Gasket Diameters
Part Number: 1069
Principal Application: GM Family of Cars/Trucks (64-97)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.338
Outer Diameter Top: 3.660
Thread Size: 13/16-16
By-Pass Valve Setting-PSI: None
Beta Ratio: 2/20=2/26
Burst Pressure-PSI: 225
Nominal Micro Rating: 19
Gasket Diameters
Attached 3.444 3.100 0.260
This is the Napa filter for a Corvette.The only one for a 928 is the gold. There is a difference.
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.338
Gasket Diameters
Man of many SIGs
Originally Posted by ZEUS+
Part Number: 1069
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.338
Gasket Diameters
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.338
Gasket Diameters
Originally Posted by Fabio421
What point are you trying to make? Maybe I missed a post somewhere but what does a Corvette filter have to do with this subject?
Rest in Peace
Napa filters are made by WIX. Even their filter #'s are the same. Napa drops the first digit from the WIX #.
I do not belive that is correct, but I could be wrong.
I could have sworn I have seen a Mahle or a Mann Stamp on some of there European filters.
Man of many SIGs
I am not trying to make any point at all. Just an example. Corvette, small block chevy, whatever. The Napa Gold is made better than other filters. Thats all.
Originally Posted by Blown 87
That is a big brush you have, to say all of them are made by WIX.
Inventor
My '86 came with a NAPA filter which was much smaller than the OEM.
