928 Forum 1978-1995
Sponsored by: 928 Specialists
Don't remove the ignition amps...
Old 11-25-2016, 09:59 PM
  #31
Imo000
Captain Obvious
Super User
Imo000's Avatar
Originally Posted by The Forgotten On
90C is a pretty common number to hit with thermal compound for PCs, at least with video cards and some AMD chips (looking at you 9590).
My GTX 690 has a tdp of 300 watts and can get pretty toasty if the fan isn't cranked. It will sit at 70C+ pretty comfortably along with my processor, both using Arctic 5.
The -C numbers are common too as some competitive overclockers use liquid nitrogen to cool their CPU and GPUs along with some users using phase change cooling (imagine a AC evaporator as a metal plate mounted flush to your CPU).
Anyway, this isn't a PC forum, but there shouldn't be any issues with CPU thermal compound so long as you replace it every 3 years or so to keep it fresh.
Sounds good but no one will change it every 3 years. It needs to last for the life of the car.
Old 11-26-2016, 02:40 AM
  #32
The Forgotten On
The Forgotten On's Avatar
I've left mine on for 7 years on my CPU, so far no problems. Realistically you could run it for over 10 years no problem, 3 was just the average change time on most computers.
Old 06-27-2018, 02:24 PM
  #33
Adamant1971
Adamant1971's Avatar
So what paste should be used. Hoping I can source something locally as my amps arrived sans paste.
Old 06-27-2018, 02:47 PM
  #34
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,072 Likes on 1,183 Posts
Any computer store should have some, same substance that goes between CPU's and heat-sinks.
Some Best Buy's even stock thermal paste:
https://www.bestbuy.com/site/insigni...?skuId=5974700
Old 06-27-2018, 03:51 PM
  #35
SeanR
SeanR's Avatar
Just a data point. I stopped installing Huco's a few years ago after a set failed on my car, and then shortly after, a customers car. Bosch only for me.
Old 06-27-2018, 04:13 PM
  #36
Adamant1971
Thanks Eric, that's what I figured but great to have confirmation.
I purchased bosch units.
Old 06-28-2018, 03:59 PM
  #37
Schocki
Schocki's Avatar
People in Germany had problems with Beru units too. Buy Bosch and you are fine. Replaced my aging ignition modules with Bosch about two years ago, no issues. Car runs just great!
Old 06-28-2018, 09:01 PM
  #38
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
Like fuel lines right?
Old 06-28-2018, 09:16 PM
  #39
Jim Devine
Jim Devine's Avatar
Although not about ign modules, the computer shop I use swears by ARTIC SILVER 5. He says the fans run less than with other products, indicating the chip(s) are running cooler = better heat transfer, which should apply to ign modules too.
Clean the mounting area(s) very well- full contact is important & use as directed.
http://www.arcticsilver.com/as5.htm
Avail @ Amazon, EBAY etc
Old 06-28-2018, 10:12 PM
  #40
The Forgotten On
I have like 3 tubes of that stuff lying around lol.
I use it when I deep clean my graphics cards and CPU.
It works well and is relatively cheap so it should be fine for this application considering the parts aren't sitting at 80C constantly.
Old 06-28-2018, 11:03 PM
  #41
Adamant1971
QUOTE=Jim Devine;15109913]Although not about ign modules, the computer shop I use swears by ARTIC SILVER 5. He says the fans run less than with other products, indicating the chip(s) are running cooler = better heat transfer, which should apply to ign modules too.
Avail @ Amazon, EBAY etc[/QUOTE]
I went to a local computer shop on the way home today and got just that. They said it's the best.
Quick Reply: Don't remove the ignition amps...
