gasket - worst luck
#34
Fleet of Foot
Originally Posted by juvius
engine seems to run great prior to this.
BTW, I live in the Eastlake area
#36
For the record, the manual says oil capacity is 7.5 liters. Another source quoted on Pirtle's site says 7.5L plus .5L for filter change. I'm sticking by my original assertion that you're too full, Juvius. Drain some out. Hopefully you didn't do any damage.
#38
Fleet of Foot
Mine takes 9 Quarts with the filter. Both 928's I have owned do.
#43
My last oil and filter change it took close to 9 litres to get it to the full mark.
steve is it possible you spilled some oil under the hood somewhere; like on a exhaust pipe?
#44
Fleet of Foot
so, other than a blown headgasket, is there any other way that coolant would mix with the oil?
thanks again
thanks again
#45
Juvius you dont want to enter headgasketland just yet. Incorrect fuel management can produce to much moisture also. I just dont think that is your problem either.
