TDC mark of 16v
Inventor
Oops. Lost my mind. It's 1° cam advance.
Originally Posted by PorKen
That's about 2° crank, or 4° cam retard!
Originally Posted by Shark Attack
Really I just did mine, it lined up perfect
Originally Posted by Chilton
8. Tighten the belt tensioner bolt until the belt can be twisted only 90° between the tension roller and the right camshaft sprocket.
2degree movement of the crank is going to be 1 degree on the valves. good catch. i forget that the pully on the crank is the little tiny one behind the harmonic balancer. one rev on the crank = 1/2 rev on the cams.
MK
MK
Just a follow up to this thread.
How I got the cams to align was an offset key grinded to the 16v size (4mmx4mm). Took me 2 trys and 1 hour.
My left cam was advanced 2 deg. Right cam was on the mark.
I ended up using a Ford 2.4L offset key by 1 deg. Now both cams are synchronized and advanced by 2 deg.
HTML Code:
It is hard to see the marks. I painted the slot with nail varnish (do not ask the colour) and I slid a long thin screwdriver in the tooth trough to check the correct point.
Marton
toofast, can you get the offset keys at a parts store or did you have to go to a dealer?
I've doing a tb/wp job on an 84 right now. I'll check the TDC mark on the balancer and see if I get the same result as you did.
Thank Porken,
Is the third column crank or cam degrees?
I'd like to be able to estimate which part # I'm going to need by looking how far off the cogs are without pulling out the degree wheel. If I can see that for example, the cog is 3/4 of a tooth off, would part # "01 67" be the one I'm looking for? (Showed my work below for extra credit)
Maybe add a fifth column to the above chart for easy reference indicating:
04 - .46 cam tooth width
02 - .6 cam tooth width
01 - .73 cam tooth width
0 - .86 cam tooth width
Part number | Offset | Degrees | Plus One Tooth Degrees
621 991 04 67 | 0.7mm | 3.483 | 4.017
621 991 02 67 | 0.9mm | 4.475 | 3.025
621 991 01 67 | 1.1mm | 5.464 | 2.036
621 991 00 67 | 1.3mm | 6.450 | 1.05
Inventor
Mercedes#: 621 991 0* 67
* | Offset | C° _% | ±1 %
4 | 0.7mm| 7° .46 | 8° .53
2 | 0.9mm| 9° .60 | 6° .40
1 | 1.1mm| 11 .73 | 4° .27
0 | 1.3mm| 13 .86 | 2° .13
%: fraction of a tooth
±1: one whole tooth + key
one cam tooth is 15 crank°
